BentWing
FL, USA Status: offline
Richard, I am flying an Ultra Stick and it is a ton of fun to fly, and gets away from the 'trainer' flight characteristics... since it has a symetrical airfoil. I flew this plane for 3 weeks, and was able to fly my friends TF 60 Corsair around with no problems at all... little different, but as far as weight, they were about the same and both landed almost identical, the corsair needing a little bit more power, but that's it. I'm hoping to aquire a TF Spitfire here soon... just have to find the time to build it So that's my path to a warbird... never flew a trainer like in your case, just a Stick. The TF kits are great in my opinion, if you build one i'd suggest glassing it instead of monokote, you'll be thankfull you did. Best of luck to you and your P-47 when you get to it. Happy Flying!
_____________________________
Chris "Happiness Is Flying Inverted"
