RE: show us your 1/2 A models
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: show us your 1/2 A models Page: <<   < prev  1 2 3 4 5 [6] 7 8   next >   >>
Login
RE: show us your 1/2 A models - 1/24/2005 5:04:03 AM
burtcs
Status: offline
This is my Bowers Flybaby - 1/2A RC Texaco:
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to fadmuker)
       Post #: 126
RE: show us your 1/2 A models - 1/28/2005 5:28:35 PM
cortacesped
Status: offline
This is my .049 Baby Trainer. I don“t know how she survived so many crashes. I love this plane. Now she is equiped with std RX, 3 HS 81 and a RC Bee w/ throttle sleeve (Thanks AJC).
Claudio
Click for fullsize
(in reply to burtcs)
       Post #: 127
RE: Pictures of 1/2 A planes - 1/29/2005 7:51:08 AM
2oldultimates
Status: offline
quote:
ORIGINAL: Neil Guildford
My Decathlon didn't really fly a scale speed. 3 attempts at take-off all caused a hard left turn on the ground. Then I tried a hand-launch, which was a bit light and caused it to fly straight into the ground (broke the undercarriage). One last try, a hard throw into wind. It banked left and then immediatly came under control.
I was flying this thing faster than the other guys with there 40 size models. Unlimited verticle, stall turns, axial and barrel rolls then lot.
Having no undercarriage I cut the engine on finals and glided in. It was easy until the last foot when it dropped, luckily flat on its belly (no further damage).
I'm going to replace the OS 15LA with my AP Hornet 0.9.
I converted my wattage decathlon using an AP .061. The engine fit completely inside the cowling. Plane weighed in at 16oz with an onboard glow driver, HS-55's, and a 1.5oz tank. Flew very fast for its size and was very aerobatic. It always drew attention at the field and most guys would stop flying to watch it fly. It couldn't do a rolling takeoff either. I always had to hand launch it. Landed great though.
(in reply to Neil Guildford)
       Post #: 128
RE: Pictures of 1/2 A planes - 2/9/2005 6:33:35 PM
BrykMantis
Status: offline
twister55,
I've had a few of these 1/2a Stealths and have always loved them. They fly great and even make a Intermediate Flyer like myself look good.
One thing I didn't like was the 3-4 minutes of flying time. So, in order to fix this, I placed an additional 1oz Fuel Tank between the Elevator and Aileron servos. The square 4cell flat pack receiver battery rests on its edge up against the firewall (padded). After that I got 8-9 minute runs with a Cox TD .049 that tore up the skies on 20% Nitro fuel. Trust me, it really is easy and well worth while.
Note: The breather line from the interior tank attaches to the pressure tap on the engine...
The fuel line from the interior tank attaches to the fill tap on the TD...
The fuel feed line on the TD attaches to the Carb (Reed Valve)...
The overflow on the TD is blocked (small fuel line and screw) to allow the circulation via vacuum (think of it like an electric circuit)...
When you fuel. you unhook the pressure line and attach your syringe (whatever) there and unblock the overflow. When fuel comes out the overflow it is ready. REMEMBER to reblock the overflow and replace the pressure or the circuit will not work when you are finished fueling.
Also, make it so the cockpit is removeable (after the first one I didn't even bother with a cockpit...too much DRAG).
I read here that a couple of people were using two aileron servos. What a waste of extra weight. If you just heat up your flexible pushrod tubing in boiling water and hold the shape you want it works like a charm. Mine never failed or bound because I followed the instructions.
Finally, REINFORCE the tailgroup by using servo screws ( at least 4, 2 each side ) to hold the horizontal stabilizer to the booms. On my early versions this was the first place that failed ...ending in disaster.
GOOD LUCK
casabryk
_____________________________
Learn from the mistakes of others. You won't live long enough to make all of them yourself.
(in reply to twister55)
       Post #: 129
RE: show us your 1/2 A models - 2/21/2005 4:33:16 PM
A. J. Clark
Status: offline
Here's Simple Simon. This was the first plane I was going to build when I started RC. I was talked into building something else for my first plane. I build the fuse which sit on the frig top for many years. It's all done now. Just waiting on spring.
Click for fullsize
Click for fullsize
Don't be afraid to throttle it up.
       Post #: 130
RE: show us your 1/2 A models - 2/23/2005 6:00:04 PM
A. J. Clark
Status: offline
My other 1\2A project I finished last fall. Hasn't flown yet. It's called Weekend Wonder. Used an ace foam wing and painted the fuse with Balsa Rite.
A. J. Clark
Click for fullsize
Click for fullsize
       Post #: 131
RE: show us your 1/2 A models - 2/23/2005 6:33:21 PM
Bipe Flyer
Status: offline
I did the same thing using only 1 ACE wing panel.
Click for fullsize
1/2A all the way!
Club Saito #151
(in reply to A. J. Clark)
       Post #: 132
RE: show us your 1/2 A models - 2/23/2005 7:05:20 PM
BuzzardsFly
Status: offline
Nice, does that wing have anhederal, or is itan optical delusion ??
Bipe, nice is it fast ??
Chris
Lynn S. the wind beneath our wings.
       Post #: 133
RE: show us your 1/2 A models - 2/23/2005 8:10:29 PM
Bipe Flyer
Status: offline
Yest it WAS very fast.
It weighed 226g (8oz) and had a Norvel AME .061 in it. I still have the wing. I should build another with an .020
1/2A all the way!
Club Saito #151
(in reply to BuzzardsFly)
       Post #: 134
RE: show us your 1/2 A models - 2/23/2005 9:22:01 PM
hfenn
Status: offline
I did the same thing with a single constant chord Ace molded foam wing panel to make a Micro Hots. Cox TD .020. I did this in '91 so the smallest servos were Futaba S133 and a 114 Rx, made a 50 mAh battery from cells out of a rechargable 9v. I probably should revisit this because I know I could outfit it for a much lighter flying weight now.
Click for fullsize
(in reply to Bipe Flyer)
       Post #: 135
RE: show us your 1/2 A models - 2/24/2005 3:53:54 PM
Javier-RCU
Status: offline
ME-163 Komet form MAN july 1999 issue. WS:30", Wt:28oz, OS 10fp.
Javier
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to hfenn)
       Post #: 136
RE: show us your 1/2 A models - 2/24/2005 4:38:10 PM
DustOffUH1
Status: offline
Cool planes! Here's my Herr J3 Cub. 48" wingspan, 3 servo's, throttle, rudder and elevator. It has a Norvel .061. I also put Curtek lights in it. Red & green on the wingtips. White landing lights, one on top and one on the bottom. Nice kit to build. Hasn't had its maiden yet. I'm also building the Herr Cub "windy day park flyer". I have the wings and fuse done, but that one is up in WI (my vacation build project). That's going to be electric powered by a Sprint 280.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Lots o Planes & Helicopters. 5 more planes & 1 heli to build ;)
(in reply to Javier-RCU)
       Post #: 137
RE: show us your 1/2 A models - 2/26/2005 5:22:13 AM
A. J. Clark
Status: offline
Ya it has a slight bow to it. It was suppose to be straight. Not sure how or when it got that way. Those things happen sometimes you know.
A. J. Clark
       Post #: 138
RE: Pictures of 1/2 A planes - 2/26/2005 6:33:08 AM
Bipe Flyer
