bob27s
OH, USA Status: offline
Bubble-free tanks are certainly an excellent, EASY addition even for sport racing. If the goal is to keep racing simple, using the tanks removes one of the biggest variables out there.... fuel systems. A slight big of foaming, a tiny air leak.... those things can drive experienced pilots nuts, and drive novice racers totally insane! The engine runs are always consistant, you dont have to worry about blowing a plug if the fuel gets low. Glow plugs cost what... $3-4 each. Consider the investment in a tank and filler a decent trade between blowing a handfull of plugs. Even to a beginner, this tends to make sense. Lon, don't worry if you only are getting about 3 or 3.5 oz of fuel in your fuel tank. If a 4oz regular tank was enough in the past, the 3ozs will be enough. A regular 4oz tank might hold a total of 4oz, but when you get down to actual operating volume with a clunk, tubes installed, plus the safety margin you need to maintain(considered unusable fuel... for racing, about 1/4 of a tank) you basically only have 3 oz available. With a properly set up bubbleless tank, you can draw every last drop of fuel without worrying about the engine going lean. So, your 3oz bubble tank will get you just as far or further than a regular 4oz tank. Jett will have 4oz tanks available shortly. Lots of requests from 424 and combat pilots. I will check on the availability date. Currently have 6oz (actually 5.5 oz) in three shapes, plus a 12oz available. The bladders he uses, when used properly with the fueler, will never wear degrade or break. It is still best to use the jett fueler for filling bubble-free tanks of any kind. Its one of the best investments you can make for racing. Draw the air out, and put the fuel in all in one operation. It sure beats the older small syringe and having to clamp off the line between vent and filling operations. There are a few other similar products available. Each will do the job, and all are worth the investment. Bob Brassell
