Piccolo Tail Motor Help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Piccolo Tail Motor Help
Page: [1]
Login
Piccolo Tail Motor Help - 10/28/2003 8:49:04 PM
-Ender-
Status: offline
I have the 310 tuning motor, will I need to get a larger tail motor as well? right now I am having trouble getting the tai motor from reaching a speed that will counter act the yaw induced by the main motor. I am thinking that it is the result of having training gear on and the main rotor has to run at higher speeds to lift off. Will a bigger tail motor help?
       Post #: 1
RE: Piccolo Tail Motor Help - 10/29/2003 6:03:33 PM
Gary Morris
Status: offline
Piccolo's are nortorious for the stock tail motors having longeviety problems. One solution is to replace the stock motor with a new motor, or you could put on the high authority Piccolo Pro motor....but....if you do that then you will reduce your flight times, have a very tail heavy Heli and all sorts of other problems.
I would recommend first making sure that the tail motor gear lash is set very very loose and the silicone tubing is not pressed tightly up against the bearings. If you have flown your Piccolo for awhile you might just want to replace the tail motor. My first tail motor lasted about 5-6 flying hours, not too long considering everything.
Hope this helps!
Gary
(in reply to -Ender-)
       Post #: 2
RE: Piccolo Tail Motor Help - 10/29/2003 8:02:07 PM
-Ender-
Status: offline
Thanks I'll try a new stock motor first.
(in reply to Gary Morris)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.500RCU1
