Flyfalcons
WA, USA Status: offline
An IMAC buddy had two 106s that crapped out (one started grinding itself up, one had an uncontained failure) - a lot of us at an event were trying to get one of them to run right but we couldn't get it just right for some reason. Bobby told him the second one was improperly mounted, when it was mounted the same as all the other engines that guys are running in IMAC (including those running 3Ws). He gave up on his 106s, bought DA-100s, and is swinging the same prop and according to him, getting the same performance. Ask Otter about his two 3W's. I believe he got both of his from Bobby, but not 100% positive. He's now flying DA. There was also the one that crapped out in a Carden Edge during a low harrier after flying most of the summer and running very well. Not sure what he did with the engine afterward as far as selling or keeping it. FormerCA, John isn't full of it, I've been exposed to something like 7 3W's on a regular basis this past summer, and above is what happened to five of them. I was running a GT-80 last summer, so I wasn't particularly critical of either manufacturer until I watched these things happen. Now, DAs aren't 100% perfect but you can bet that if you have one that isn't running right, that DA will take care of you and not send your engine back until it is running properly. Based on what I've seen, you may not get that from Bobby. That peace of mind is what prompted me to do business with DA. If you are happy with 3W then keep using them but neither JohnVH nor I are lying to you about what we've seen.
_____________________________
Ryan Winslow Cub flying - the new EXTREME SPORT!!! (evarrr)
