2 stroke fuel in a 4 stroke engine?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 stroke fuel in a 4 stroke engine?
Page: [1]
Login
2 stroke fuel in a 4 stroke engine? - 11/1/2003 11:30:41 PM
racer8297
Status: offline
Would it create a problem to use my 2 stroke 10% fuel in my Saito 100 4 strike engine? Aside from the performance difference (because of the lower nitro content) would using the 2 stroke fuel create any damage?
TIA,
Jim
       Post #: 1
RE: 2 stroke fuel in a 4 stroke engine? - 11/1/2003 11:47:39 PM
Ilikebipes
Status: offline
I never use 4 cycle fuels in my 4 strokes. I used 10% on my Saito 100 to start with, and it never ran well. I switched to 15% and the results are much better. Now I'm using the Byron or Powermaster 30% heli fuels, and there is no comparison. MUCH stronger, and the idle and throttle transition is very smooth.
I would use no less than 15% nitro in my Saitos. My magnum 4 stroke works well on 10%, as well does OS and TT.
(in reply to racer8297)
       Post #: 2
RE: 2 stroke fuel in a 4 stroke engine? - 11/1/2003 11:48:42 PM
William Robison
Status: offline
Jim:
If you check the Saito paperwork it says 10-15% nitro, and wants 20% oil. "Four-Stroke" fuel is generally lower oil than "Two-Stroke," and the 2c is commonly 16-18%. They also say a bit of castor oil is nice.
Add all this together, Cool power with addition of 3 ounces castor oil per gallon, or Omega straight out of the bottle.
Bill.
_____________________________
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
       Post #: 3
RE: 2 stroke fuel in a 4 stroke engine? - 11/2/2003 3:34:49 AM
daveopam
Status: offline
I never run 4-C fuel. Power master 15% will make it humm. 30% if you want some extra kick.
David
(in reply to William Robison)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU4
