RE: Skyshark Aichi (VAL) Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Skyshark Aichi (VAL) Build
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: Skyshark Aichi (VAL) Build - 1/5/2004 7:11:44 PM
grahamd1
Status: offline
And a bit more done
(in reply to grahamd1)
       Post #: 101
RE: Skyshark Aichi (VAL) Build - 1/5/2004 10:56:01 PM
tubig
Status: offline
graham, your cockpit is looking nice. are all of the details you've added so far supplied with the kit or is there some scratch building in there too?
       Post #: 102
RE: Skyshark Aichi (VAL) Build - 1/6/2004 1:16:28 AM
Mountain Man
Status: offline
I've been reading with great interest.
I wanted to do a Corsair or a P-40 at first. With all the talk about 90 degree rotating retract problems I think I'm better off with fixed gear or regular retracts. Am I being too concerned about retract problems? I really like the Corsair. Would a .90 (4c) fit in that cowl?
Any other kit suggestions for that size engine?
Jim
       Post #: 103
RE: Skyshark Aichi (VAL) Build - 1/6/2004 3:12:35 AM
w0mbat
Status: offline
Jim,
I wouldn't suggest putting anything larger than a .72 4-stroke in the Val. I am currently flying one with an OS50SX and it is way overpowered. (and I like to overpower planes). Any of our other planes (except the Dauntless and Tempest) will fly great (and even be slightly overpowered) with a 90 4-stroke.
I have always had problems with the Robart 615's. I have had them in a TF P-40 with terrible results. They seem to hold up pretty well in our Hellcat and Skyraider as long as they are flown off pavement. But both planes come in under 8 lbs. The main problem that I continually have is getting the gear to come down while in the air. The wind resistance doesn't let them lock down completely. I usually tell people to skip the retracts and use fixed gear if they are flying those 2 planes off grass. I hate to bash a product that we sell, but I know how fustrating it is to work hard building a plane and have the retract fail on every flight!
I have tried to fit the Century Jet in our planes, but the cylinder is just too large. Same with the Sierra Precision. We are currently working on some new ideas to try and fix the problem - but like anything, it take time!
Mike Grey
Skyshark R/C
(in reply to Mountain Man)
       Post #: 104
RE: Skyshark Aichi (VAL) Build - 1/6/2004 11:38:04 AM
Wulfman
Status: offline
Hi Mike,
Have you considered mechanical retracts, with a sail winch servo?
I love the Val, what great airplane! Looks like a nice kit. I bought your Stuka, haven't started it yet though.
SC
(in reply to w0mbat)
       Post #: 105
RE: Skyshark Aichi (VAL) Build - 1/6/2004 12:15:38 PM
Bars
Status: offline
Good afternoon. A question! Than you cut out preparations?
(in reply to Wulfman)
       Post #: 106
RE: Skyshark Aichi (VAL) Build - 1/17/2004 3:35:27 AM
Canuck1
Status: offline
Couple of pics.
Craig
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Bars)
       Post #: 107
RE: Skyshark Aichi (VAL) Build - 1/24/2004 12:06:25 PM
grahamd1
Status: offline
I sprayed on the primer coat last night, so I can spend the weekend rubbing down, and laying down the panel lines.
Click for fullsize
       Post #: 108
RE: Skyshark Aichi (VAL) Build - 1/25/2004 5:55:04 AM
Canuck1
Status: offline
Looking good Grahamd1. Hopefully mine will be at that stage soon. Been spending far to much time on the Lanc. It is good to have a couple of planes on the go. I am at the stage of hinging all of the surfaces. I will use robarts except for the flaps. I plan on using flat Dubro hinges for that. Keep the pics coming. I have attached a couple pics. Still needs some cosmetic work with regards to sanding and shaping. I do like the feature with this kit of the seperate trim tabs. This will look great when it is scaled up. Have not done any cockpit work as of yet. Still thinking of the best way to paint it. I know the detail will be lost but that is not an issue, just have to do the details from scratch.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Canuck1 -- 1/25/2004 6:37:10 AM >
       Post #: 109
RE: Skyshark Aichi (VAL) Build - 1/25/2004 8:09:12 AM
grahamd1
Status: offline
Craig I sprayed my cockpit with a mixture of 50/50 enamel/thinners, even after two coats I could still see the detailing lines. Mike recomends Krylon sprays, but we dont have it in the UK.
(in reply to Canuck1)
       Post #: 110
RE: Skyshark Aichi (VAL) Build - 1/25/2004 9:25:25 AM
Canuck1
Status: offline
That sounds like a good option. I wonder if Krylon Paint comes in the colour needed for the cockpit? I know on one of the paint sceme papers that came with the kit, it mentions Krylon for the finish colour. I am not to sure on its fuel proof qualities? I may have to check that option out even for the finish coat. It is a heck of a lot cheaper than the hobby paints!!
Craig.
       Post #: 111
RE: Skyshark Aichi (VAL) Build - 1/27/2004 4:33:47 AM
Canuck1
Status: offline
Worked on the flaps tonight. They turned out well, better than I thought they would. I have attached a couple pics. Wheel pants are next, and I have been dreading this part.
Craig.
Click for fullsize
Click for fullsize
       Post #: 112
RE: RE: Skyshark Aichi (VAL) Build - 1/27/2004 7:35:28 AM
grahamd1
Status: offline
Thanks Craig, I need the kick up the A*s to get on with re-doing my flaps.
Graham
       Post #: 113
RE: RE: Skyshark Aichi (VAL) Build - 2/29/2004 1:48:34 PM
grahamd1
Status: offline
Started applying the primer (light grey Enamel)
