notasme
IL, Status: offline
Spfdrek, Darth, Lyk2fly, Spfdrerk, you are correct the longer shaft is for the cone start. I thought about the rear exhuast but I did nt want to deal with how to mount it. There are some other mufflers for the side mount that I think could workout better then the one I have but this was a matter of availability and time. Today was to cold and to windy to fly. Maybe yet this weekend (can't wait). Darth, I have the CP mod built and sitting ton the bench. I like to make one change at a time and prove it in before making another change. Lyk2fly, I agree with what you have said about the clutch. Also I feel that haveing baerings in the engine if far better then bushings (like v7). I also thing that haveing bearings supporting the clutch is better and puts less strsee on the shaft. I think that you could use the starter cone from the v7 by drilling it out. You may also find that a small local machine shop would turn the shaft for you (if you wanted to go that route). I know many people that fly heli's have bought small lathes or have friends that have one. I have made parts for people that I have flown with and after they worked with me on making parts went out and bought a lathe. You can get some nice small lathe's that for under $400.00. Once you have one you would be suprized how many thing you will use it for.
_____________________________
notasme
