2engsout
Hi Guys, Jim Nicosia in Minn has built and flown five of these, and has given me some great advise on the Ziroli D-18. I bought one almost RTF and it already has the servos mounted in the rudders. Thats the BEST place for them Kevin. Use the thin JR ones. To compensate, mount the elevator servo on the ceiling inside the cabin as far towards the cg as you want. Preferably foward of the trailing edge. I am using two, 40" long .157 O.D. carbon fiber tubes for a pushrod to get mine up at the cg. Mount the tailwheel steering servo on the inside bottom of the fuse directly behind the trailing edge with cables back to the wheel. This gets as much of the servo weight as far foward as possible which lessens the amount of lead you will need to get the cg between 10 and 10,1/2" behind the leading edge measured from the fuse side. A more accurate way to mark that cg is to measure back 2.25" to 2.75" behind the flat center area that is between the leading edges. Transfer that mark to the fuse saddle and parallel a fuse former up the inside of the fuse to the ceiling of the cabin and stick a pin thru the balsa. Now mark the top of the fuse and thats where your plum bob will need to hang. Jim was not too specific where his cg was within that 1/2" window, but I will start with 2.5" behind the flat section for the 1st flight. I am also going to make a fiberglass cup from heavy cloth, glassed to the front fuse plate that will conform to the inside of the plastic nose piece that will fit right over it. This will get my ballast as far foward as possible. I'll pour small lead shot in there to get my cg and then glass over it to seal it. If you do the math, the tail to cg to ballast ratio is approx 2.4 to 1. For every ounce you save in the tail, you need 2.4 oz. less in the nose to get you to the cg. I also fly a Ziroli P-38 and the DC-3. Hope this helps. Rick
