RE: Propeller Safety Reminder
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> RE: Propeller Safety Reminder
Page: <<   < prev  1 [2]
Login
RE: Propeller Safety Reminder - 11/9/2003 10:09:52 PM
BaronSchwab
Status: offline
There is NEVER enough SAFETY with spinning props.
_____________________________
Non esse sine aircraftus.
(in reply to BasinBum)
       Post #: 26
RE: Propeller Safety Reminder - 11/11/2003 6:07:02 AM
sedunster
Status: offline
jimlynn,
I am glad I wasn't hurt that badly. Thank you for the pictures. They help make a point that no words can. I hope you heal well and quickly. (Side note, what part of Pittsburgh are you from? I grew up in Irwin, PA)
This was the main reason I originally posted this topic. If you have not been bitten by a propeller, the energy and force contained in that little package just doesn't make an impact on you. (no pun intended) RESPECT WHAT IT CAN DO TO YOU!!!
(in reply to BaronSchwab)
       Post #: 27
RE: Propeller Safety Reminder - 11/11/2003 8:07:08 AM
jimlynn
Status: offline
I'm getting the stitches out day after tomorrow (11/13/03) No swelling, no infection, little pain (after the first three days of narcotics induced mental dial-tone behavior)....
I'm looking at a little physical therapy and a slight possibility of corrective surgery in the spring if the tendon's don't heal correctly (they are feeling better every day!).
Gonflyin: That's about how long I calculated. Had to explain it to the doc. He kept wondering why I didn't jerk my hand back after the first couple of slices!
Sedunster: I'm not from here originally, moved here in '75. Live in Beechview, work on North Side, near new stadium (baseball one)
< Message edited by Lightfoot -- 10/29/2006 1:07:06 PM >
That was interesting. Can you do it again on purpose?
(in reply to sedunster)
       Post #: 28
RE: Propeller Safety Reminder - 11/12/2003 6:01:07 AM
causeitflies
Status: offline
Jim, I knew those pictures would make you famous The hand looked even scarier in person
Glad everything is healing up so quickly.
You can always bring a plane out and watch me fly it .
Mark P
An Expert has made every mistake - A Master has made every mistake twice
(in reply to jimlynn)
       Post #: 29
RE: Propeller Safety Reminder - 10/27/2006 11:42:24 PM
Timex10
Status: offline
I'm new to this. Is it recommended to wear gloves when starting an engine?
"I've got to concentrate, concentrate, concentrate."
(in reply to causeitflies)
       Post #: 30
RE: Propeller Safety Reminder - 10/28/2006 2:39:32 AM
drdenny
Status: offline
Actually, in my experience of over twenty years, I don't think that gloves are such a good idea. Yes, they might offer some protection, but by the same token, may give you a false sense of security. I have been "bitten" several times because I was not paying enough attention to what I was doing..including just last week when I was bitten by a pusher prop on an electric plane. The bottom line is that you really need to take your time, and be observant of your surroundings. It only takes a split second which can cause you and others pain which is totally preventable. We all need to BE CAREFUL!! Good luck in your new hobby!
drdenny
AMA# 860636
(in reply to Timex10)
       Post #: 31
RE: Propeller Safety Reminder - 10/28/2006 4:54:03 PM
Checklst
Status: offline
Great thread and Yes we all need to think safety more. As for me KNOCK ON A WHOLE LOT OF WOOD I have never hit my hands or fingers and I have been doing this since 1980. I did have a APC hit me in my right eye as it was spit off a 4 stroke, man you should have seen the cut damage to my Sun Glasses (safety rated)it still got my cheek,those APC's are sharp and nasty for sure............ I use to only where my glasses when I was starting or flying, and would remove them in the pits when I was talking to people, I just happen to have them on as I was coming off the flight line,......NOW I WEAR them always.
(in reply to drdenny)
       Post #: 32
RE: Propeller Safety Reminder - 10/28/2006 5:30:03 PM
Checklst
Status: offline
Opps
< Message edited by Checklst -- 10/28/2006 5:31:00 PM >
       Post #: 33
RE: Propeller Safety Reminder - 10/28/2006 11:35:50 PM
saleens7
Status: offline
even though drdenny said that gloves arent as good as they seem, you can fashoin some that will protect you a LOT more than regular gloves....being an airboater...(not a flyer), it still has the same safety issues....what i would do to make a glove that will protect your hand, and the prop too , is to wrap a glove in 1" thick insulation foam...wrap it around the glove w/ the fingers closed, dont wrap each finger individually, if you do, your fingers will have a 2 inch gap between eachother, and it get very uncompfortable like that . so wrap it around the whole glove and then epoxy (no superglue, melts foam) a 1/4" thick rubber lining around it....the foam will absorb the impact, while the rubber will keep it from slicing through the foam and to your hand....it also protects the prop too..
this is only good for starting....it will not let you adjust the carb or anything else due to limited hand movement...also, i dont think it will protect you from the prop at 1/2 or full throttle, it will be moving with enough momentum and speed to just cut through the rubber
hope this helps....never tested it, but it should work...
PS, use thick rubber, not the light, easily cut, rubber....
saleens7, the wookie of RC
(in reply to Checklst)
       Post #: 34
RE: Propeller Safety Reminder - 10/29/2006 2:05:53 AM
drdenny
Status: offline
I did not say that they aren't as good as they seem...I said that they might offer some protection, but could be a false sense of security. We are working with aircraft here, not boats. It would be way too combersome to try and put all of that padding on your hands when you are trying to get the aircraft flight ready.
quote:
ORIGINAL: saleens7
drdenny
AMA# 860636
(in reply to saleens7)
       Post #: 35
RE: Propeller Safety Reminder - 10/29/2006 3:13:49 AM
Cyclic Hardover
Status: offline
quote:
ORIGINAL: Timex10
Only if you use your fingers Which by the way is not a wise thing to do.
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
       Post #: 36
RE: Propeller Safety Reminder - 10/29/2006 3:29:24 AM
Charlie P.
Status: offline
Start it and then get behind it. That's the only safe way.
A few years ago our club had built and installed starting tables over the winter. First time I was using one I was at the field with a friend. We both wanted to tune our engines before flying (it was the first warm April day). I started mine and he did the same about 10 feet to my left. I don't have a rechargable glow starter, and I was gathering up my field box from the ackward spot I had it balanced to use the battery when suddenly I was sprayed with blood. I wear glasses and couldn't see out of my right lens! I'd wrassled with a chainsaw years ago and I know shock and nerve damage can keep you from feeling the initial hit, so I backed up and dropped my box and started to flip my hands to see what I'd done. Then my friend sat down hard on the ground in front of his plane. He'd reached through HIS prop and I caught the spray. 21 stitches for him and four hours later I drove back in the dark to retrieve our equipment.
Turns out he'd started his plane and set his NiCad glow starter on the table behind the upright wing supports. As he was running the throttle up he noticed the glow starter rolling towards him under the fuselage and, to keep it from rolling off the starting table, reached for it . . . through the prop.
Only takes 1/10 of a second of forgetfullness or inattention.
Back in ny early flight days we started the little 0.049 and 0.15 engines by hand flipping or with counter-wind spring starters behind the props. I've got 35 year old scars from some of those little motors. More hurt friom the knuckle rap than the cut, but it got your atention.
Charlie P.
"Gravity is weak but it is persistant" AMA 747089/IMAA 30723
Oh Lord, your earth is so hard and my planes are so frail.
       Post #: 37
RE: Propeller Safety Reminder - 10/29/2006 7:48:21 AM
Flyboy BigK
Status: offline
I know the feeling there,
luckily when I made my slipup my engine was still in idle and
the prop, (which happened to be APC), only caught the tip of
my little finger took off a bit of my fingernail and kind of split
it. Though the impact of it busted open my finger.
It's not broken until the C.A. is empty
and duct tape cant fix it!
(in reply to Charlie P.)
       Post #: 38
RE: Propeller Safety Reminder - 10/30/2006 4:09:06 AM
air mail rcu
Status: offline
We also have starting tables at our field. They are only big enough for the plane. Everything else is to be set on the ground. One day a friend was starting his plane and I was standing to the side about 15 feet away talking to another friend. I noticed that the man starting his plane had his Tx on the table beside the running motor. Before I could say anything to him he reached for the radio. 34 stitches later we took some pictures, it wasn't pretty. Funny thing about 3 months later I saw the same man doing the same thing. This time I was able to say something before we had to go to the hospital again. Some people never learn.
Take-offs are optional. Landings are mandatory.
(in reply to Flyboy BigK)
       Post #: 39
RE: Propeller Safety Reminder - 11/6/2006 12:47:40 AM
air mail rcu
Status: offline
Here are the pictures. After that would you do the same thing again? I might have to rethink where I put my Tx. This was not me. See previous post.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by air mail rcu -- 11/6/2006 3:35:03 AM >
(in reply to air mail rcu)
       Post #: 40
RE: Propeller Safety Reminder - 11/6/2006 2:34:20 AM
rare_bear
Status: offline
yes, you never think it will happen to you until it does.
this is last years result of changing procedure 1 time out of 1000 times of starting an engine:
click here and here
my startup box is one of those kind that has legs and a bench that folds out. i normally would pull the
