Layup Void Repair Help required!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Layup Void Repair Help required!
Page: [1]
Login
Layup Void Repair Help required! - 11/4/2003 7:42:27 AM
tyrolean_marcus
Status: offline
Good Day All,
I have a very nice hollow molded slope sailplane from Valenta models. Unfortunately there seems to be an area in the upper wing surface that has a resin void. The result is that the area of the void has collapsed and has produced a depression on the wing surface.
How can I repair this defect?
I've attached a picture to clarify my description.
Cheers,
Marcus.
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Layup Void Repair Help required! - 11/4/2003 11:55:10 AM
Ed Smith
Status: offline
I am guessing there is dry cloth under the gelcoat or the cavity is just on the skin surface. Either way, carefully grind away the gelcoat until you are down to the cloth, try not to break through. Paint some resin in the cavity, mix up some resin and microballoons and fill the cavity. Sand smooth when cured. To disguise it paint a stripe over it or stick a decal on it.
Ed S
(in reply to tyrolean_marcus)
       Post #: 2
RE: Layup Void Repair Help required! - 11/4/2003 5:10:54 PM
davidfee
Status: offline
Marcus,
That's not a resin void. It's hangar rash. It's analogous to a ding on a surfboard. These hollow molded wings use a very light glass outer surface and then balsa (or foam) sheet, followed by more light glass (a sandwich panel). Basically, the wing skin core material has been compressed by something pressing upon the outer glass skin. Welcome to the world of hollow molded wings... you may wish to invest in wing bags.
To repair it you can very gently heat the area with a heatgun (like for shrinking iron-on film covering. This will soften the epoxy in the skin surface and help it spring back to shape a little. Be careful, since excessive heat will likely cause the paint to get small blisters in it. You can inject epoxy between the outer layer of glass and the balsa (or foam) skin using a syringe with a needle. Or you can rough up the outer surface and fill the dent with microbaloons/epoxy. Or you can just fly it as-is.
good luck,
David
(in reply to Ed Smith)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU2
