34 pound OV-10, Will it fly??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> 34 pound OV-10, Will it fly??
Page: [1]
Login
34 pound OV-10, Will it fly?? - 11/4/2003 8:48:18 PM
beavertail
Status: offline
It is powered by 2 ST 90's. It is my friends scratch built plane and can be seen at
WWW.SMASHRC.COM, I think it is the uravitch plans, but im not too sure.
I dont even want to think about an engine out situation.
Any thoughts.
< Message edited by beavertail -- 11/4/2003 8:50:59 PM >
       Post #: 1
RE: 34 pound OV-10, Will it fly?? - 11/4/2003 8:52:18 PM
beavertail
Status: offline
www.smashrc.com
If the link does not work, just try to type it at the address box on your browser.
(in reply to beavertail)
       Post #: 2
RE: 34 pound OV-10, Will it fly?? - 11/4/2003 9:03:27 PM
JWN
Status: offline
34 lbs.? Is it built from solid oak with lots of metal filled epoxy? It may fly, but at 34 lbs., I think I would want to be sure and keep an eye on it the whole time so you can be sure it's never pointed directly as you!
John
       Post #: 3
RE: 34 pound OV-10, Will it fly?? - 11/4/2003 9:28:26 PM
beavertail
Status: offline
He really went all out with it. It has retracts with doors, fully detailed cockpit, about 10 servos in all. Working nav lights and beacons.
If you go to the website and go to picture archive, you can see it.
(in reply to JWN)
       Post #: 4
RE: 34 pound OV-10, Will it fly?? - 11/4/2003 9:36:33 PM
JWN
Status: offline
I looked at it. It is very nice. But still, 34 lbs. is extremely heavy. I wouldn't recommend him trying to fly it for the first time on a hot humid day.
John
       Post #: 5
RE: 34 pound OV-10, Will it fly?? - 11/5/2003 2:28:28 AM
Wayne22
Status: offline
Is it this one?? He did a beautiful job on the scale details, but it is almost 20lbs heavier than the design weight. I have flown (an overweight) one that weighed 21lbs, but 34 lbs.....?
I wouldn't attempt it.
< Message edited by nony -- 11/5/2003 2:39:46 AM >
(in reply to JWN)
       Post #: 6
RE: 34 pound OV-10, Will it fly?? - 11/5/2003 3:20:48 AM
F4u5
Status: offline
The good news is that you have a big constant chord wing. Will probably be fine...jsut heavy.
_____________________________
Where's my glue?.......I gotta build.
(in reply to Wayne22)
       Post #: 7
RE: 34 pound OV-10, Will it fly?? - 11/5/2003 3:33:30 PM
beavertail
Status: offline
It will fly this weekend, hopefully. He is a good pilot, and has alot of warbird experience.
Ill let you guys know how it went
He told me it was 34 pounds, But ill check again
< Message edited by beavertail -- 11/5/2003 3:36:39 PM >
(in reply to F4u5)
       Post #: 8
RE: 34 pound OV-10, Will it fly?? - 11/5/2003 3:39:43 PM
Jerry Sigur
Status: offline
Can you say Hanger Queen?
Seriously, with this kinda weight I don't think it's worth trying.
Will it fly, probably if you have enuff runway, but the first
engine out situation or the first pilot mistake will probably be
the last.
It's pretty tho!
Good luck with it.
Jerry
< Message edited by Jerry Sigur -- 11/5/2003 3:40:41 PM >
(in reply to F4u5)
       Post #: 9
RE: 34 pound OV-10, Will it fly?? - 11/5/2003 10:25:58 PM
drifter
Status: offline
Are you sure it's 34 pounds? I have a hard time imagining how you could make this plane weigh that much. Mine has 14 servos, two receivers, two battery packs, retracts, a fully sheeted wing, fiberglass covering, and a latex painted finish. Oh yeah, and 2 and 1/2 pounds nose weight. It weighs a little over 21 pounds. Two St 90's pull it well. I hope 34#s was just a guesstimate. Hope the first flight go's well.
       Post #: 10
RE: 34 pound <span class= - 12/16/2003 4:51:39 PM
beavertail
Status: offline
Well, It flew, and LANDED!! He said he dialed in 15 degrees flaps and he took off about 300 feet. I had my doubts, but he pulled it off.
Hows my flying???
Call 1-800-EAT-(Censored by Moderator)
(in reply to drifter)
       Post #: 11
RE: 34 pound OV-10, Will it fly?? - 7/9/2004 9:11:36 PM
FastMover
Status: offline
What plans or views did he use to build it? Wing span info etc etc... I've wanted to build a big OV for awhile.....
FastMover
       Post #: 12
RE: 34 pound OV-10, Will it fly?? - 7/9/2004 10:12:32 PM
Shane B
Status: offline
Its a nice looking plane, my brother has been wanting to build one for a good while, what kit choices is out there for a 80" to around 100" model,
Shane
(in reply to FastMover)
       Post #: 13
RE: 34 pound OV-10, Will it fly?? - 7/13/2004 3:56:29 PM
beavertail
Status: offline
I believe its from Rich Uravitch plans. 81 inch W.S. Two Super Tigre 90's.
Go to WWW.SMASHRC.COM it is in the pictures page. just scroll around.
Hows my flying???
(in reply to Shane B)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
