Mainspar
OK, USA Status: offline
As was stated before, I'd recommend simply buying a gallon of 5-10% nitro fuel that already has a castor or castor/synthetic blend oil. I have always loved my Sportsters, from the .20, .25 (.20 overbore conversion), and .28, to the .45, and .65. They are neither intended nor generally used as racing motors. Great idle (when maintained and set correctly) and reliable. Quiet with a baffle; fine, torque generating performers without. I have also run several "modern" ABC/ABN OS-type motors, both ball bearing and not, and like them too, but I still have a warm spot in the heart for the K&B Sportsters. There have been a few occasions when someone at the field has made a comment like, "is that K&B the best you can do?".....one flip and she's running and off into the air.....after another thoroughly enjoyable flight and return to the pits, I'll find "Mr. Best You Can Do" still cranking away with an electric starter on his modern RC engine....and, the modern RC engine wasn't the problem.... Take heed of the nitro warnings already made in this thread. I have, more than once, headed off to the field after a long absence from flying with a jug of 15% nitro fuel and a sportster powered aircraft......and not until she begins to protest several minutes into the flight do I realize my mistake and bring the aircraft back to the runway and find some lower nitro fuel. Mine have all run just fine on 10%, but 15% seems to be the beginning of the trouble zone. Have a great Sportster Day!
< Message edited by Mainspar -- 4/1/2004 5:55:59 PM >
