RE: K&B 65 Sportster
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  10/31/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: K&B 65 Sportster
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: K&B 65 Sportster - 5/28/2004 2:58:17 AM
blvdbuzzard
Status: offline
On the .65's, can't you bolt the cylinder on so the exhaust is on the left?? I know there are only four bolts holding the head and cylinder on, so will it bolt on that way??? If so, how would that effect the ports???
Just a thought.
Dru.
(in reply to William Robison)
       Post #: 76
RE: K&B 65 Sportster - 5/28/2004 3:26:18 AM
William Robison
Status: offline
Dru:
The exhaust stack is not part of the removable section. And the cylinder can be installed in four different positions, you're right on that, but three are wrong and wont run properly. Because of that same port mismatch.
Bill.
_____________________________
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to blvdbuzzard)
       Post #: 77
RE: K&B 65 Sportster - 5/28/2004 4:39:29 PM
blvdbuzzard
Status: offline
I have two of the .65's but they are in planes at my brothers so I could not go out and look at them to see. The exhaust stack is a seperate piece that the muffler bolts go through from the case side and then thread into the muffler body. I was just wondering if the ones that have the exhaust on the left had the cylinder put on so the exhaust port was pointing that way.
Dru.
       Post #: 78
RE: K&B 65 Sportster - 5/28/2004 6:43:49 PM
William Robison
Status: offline
Sorry folks, I was wrong - memory failure.
The Sportster 65 can be assembled with the exhaust on either side.
Bill.
       Post #: 79
RE: K&B 65 Sportster - 5/28/2004 6:50:20 PM
William Robison
Status: offline
Here's an exploded view, partial.
Bill.
Click to see fullsize image.
Click for fullsize
       Post #: 80
RE: K&B 65 Sportster - 5/28/2004 8:27:59 PM
blvdbuzzard
Status: offline
I thought I could assemble it that way. I am glad you found the expolded view.
Dru.
       Post #: 81
RE: K&B 65 Sportster - 5/28/2004 10:54:22 PM
Richard39
Status: offline
Hello William.... Then the design will allow for the exhaust to be installed on either side? What is necessary to move the stack around..? Is it bolted on or screwed in? Thanks for this info... Richard
       Post #: 82
RE: K&B 65 Sportster - 5/29/2004 12:27:18 AM
blvdbuzzard
Status: offline
You can loosen the 4 head bolts and lift, turn the head and then tighten the 4 bolts again. Not sure if the porting of the cylinder/upper case will work as well?
Dru.
(in reply to Richard39)
       Post #: 83
RE: K&B 65 Sportster - 5/29/2004 12:46:51 AM
William Robison
Status: offline
Dru and Richard:
My memory was so bad I didn't even remember the exhaust stack was part of the cylinder, so I'm not going to say how it will run when reversed. You'll just have to look inside the case with the cylinder off, and see if there is the same relief on both sides to allow the bypass flow. If it has the clearance, it should run as well either way.
Bill.
< Message edited by William Robison -- 5/28/2004 6:47:24 PM >
       Post #: 84
RE: K&B 65 Sportster - 5/29/2004 2:18:43 AM
jessiej
Status: offline
I just pulled the cylinder off of one. Looks to me as though it should run either way.
jess
       Post #: 85
RE: K&B 65 Sportster - 5/29/2004 5:03:28 AM
blvdbuzzard
Status: offline
William, our memories are like to play tricks on us. If mine works about 15% to 20% of the time I think I am lucky. The reason your memory did not work is because you have learned so much that it had to make room.
I think I saw way back when in a model mag a guy had put the cylinder on so it was a rear exhaust and used a header for a tuned pipe to make the muffler fit in the nose of a P-38, the exhaust exited the fuse right behind the molded super chager. He was running the .65 because it would turn the big 3 bladed prop.
Dru.
(in reply to jessiej)
       Post #: 86
RE: K&B 65 Sportster - 5/29/2004 6:18:16 AM
MyWay
Status: offline
quote:
ORIGINAL: tommy157
What is everyones opinion on this engine and what would be a good price for it?
My opinion on this engine is; Stay away from this engine. It's useless when compared to anything on the market today. Value= price of scrap metal.
(in reply to tommy157)
       Post #: 87
RE: K&B 65 Sportster - 5/29/2004 6:35:16 AM
William Robison
Status: offline
Ronnie:
quote:
ORIGINAL: MyWay
You go ahead and do it your way. There are too many people using this engine with great satisfaction for it to be anywhere near as you describe it.
If you had a bad experience with one it can only be because you tried to make it work outside its design parameters.
If you tried to make a small plane go fast I have no doubt you weren't happy with it, but if you had it hauling a big plane at moderate speed you could not have been displeased.
Bill.
(in reply to MyWay)
       Post #: 88
RE: K&B 65 Sportster - 5/29/2004 8:12:35 AM
MyWay
Status: offline
We were asked for an opinion and thats what you got. No more no less. If you don't want peoples opinions then don't ask. If you don't agree then so be it.
       Post #: 89
RE: K&B 65 Sportster - 5/29/2004 9:29:32 AM
William Robison
Status: offline
Ron:
You are quite correct, sir.
Apologies.
Bill.
PS: I still think they're good engines. wr.
(in reply to MyWay)
