William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
Dru and Richard: My memory was so bad I didn't even remember the exhaust stack was part of the cylinder, so I'm not going to say how it will run when reversed. You'll just have to look inside the case with the cylinder off, and see if there is the same relief on both sides to allow the bypass flow. If it has the clearance, it should run as well either way. Bill.
< Message edited by William Robison -- 5/28/2004 6:47:24 PM >
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
