William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
Tommy: The Sportster 65 is good, so long as you remember what it is. Not a screamer at all, but a good lugger. As stated in an earlier post, avoid lean runs. Also, be sure to use at least a percentage of castor oil in tour fuel, they are plain bearing engines and need it. The lastthing, you will notice there are only four head screws, They go all the way through the cylinder fins, and screw into the crankcase. If you strip one, a new crankcase is the repair, so be careful. Kept on the rich side of peak, with castor oil, and not oversped, they are good long lasting engines. Final point - they have their own mechanical sound, unlike any other engine you've run. Doesn't mean there's anything wrong, it's just all the little men inside playing with their hammers. Feed them more methanol and castor oil, they'll keep on banging away. Bill.
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
