ChuckAuger
Joined: 12/5/2001 From: Pampa, TX, USA Status: offline
The Razors will bolt right into the GWS box. The GWS pinion will fit right on the shaft, but you would be way better off buying a new pinion instead of pulling one off the GWS motor and re-using it. A new pinion will fit a lot tighter and you won't have to worry about it slipping or using Loctite. If you are wanting a Razor 350 quickly, you might look at the Himax 2015 4100. It is very similar to the RZ350 Kv-wise, readily available, and $52. Bolts right into the GWS box, just like the Razor, same shaft size, etc. I have one on a GWS D gear drive and love it. And I have a couple of Razors as well, so I'm not anti-Razor, but it's a great little motor for the money.
_____________________________
Breaking the Speed of Sound, Straight Down!
