wheel collars
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> wheel collars
Page: [1] 2   next >   >>
Login
wheel collars - 11/6/2003 1:41:51 PM
pikebishop
Status: offline
c clips with a thin groove dremeled on the axle is lighter,never come off, and much harder to see.just cut the groove carefully and make sure the c clip has to be snapped down into the groove with pliers. works for me,cheaper too. oh yeah more of the axle can be dremeled off also as the clips are very thin compared to collars and this enhances the look of the wheel while saving weight.
       Post #: 1
RE: wheel collars - 11/6/2003 2:14:48 PM
Stripes
Status: offline
Excellent, I love tips like this.
(in reply to pikebishop)
       Post #: 2
RE: wheel collars - 11/6/2003 2:18:30 PM
Lightfoot
Status: offline
I have used push-nuts in place of wheel collars several times. The one problem is that they are very difficult to remove but how often do we remove wheel collars?
_____________________________
Howard
RCUniverse Forum Manager
R/C Flight Unlimited - http://www.rcfu.com
(in reply to Stripes)
       Post #: 3
RE: wheel collars - 11/6/2003 11:31:59 PM
LearjetMech
Status: offline
You can also wrap a piece of wire around the axle on the inside of the wheel a couple of times and then solder it to the axle. Saves a collar and reduces weight also!
(in reply to Lightfoot)
       Post #: 4
RE: wheel collars - 11/7/2003 3:04:43 PM
Stew99
Status: offline
I usually solder a washer on each side of the wheel, especially tailwheels where collars just never seem to work well. Ever since I first saw the clips on Robart landing gear struts I have thought these would be great to use instead of collars but I always assumed that it would take more sophisticated equipment to do it right.
(in reply to LearjetMech)
       Post #: 5
RE: wheel collars - 11/7/2003 5:48:34 PM
ballgunner
Status: offline
I've seen too many one wheel missing landings to be enthusiastic about wheel collars. I always solder washers on both sides of the wheels. Been doing this for years and have never lost a wheel due to the wheel collar falling off. One way is to cut the axle the width of the wheel plus the thickness of the washer + 1/64". Then punch a hole in 1/64" plywood or a calling card. Slip it on the axle between the washer and the wheel and solder the washer in place. Remove the 1/64" spacer and you have a free rolling wheel with a smooth finish on the washer which is very unobtrusive.
(in reply to Stew99)
       Post #: 6
RE: wheel collars - 11/8/2003 11:45:30 PM
redbear
Status: offline
OK, I will ask the dumb question. What are C clips and where do you get them. I hate the wheel collars because the Allen wrench set screw is never a standard size and always strips out.
(in reply to ballgunner )
       Post #: 7
RE: wheel collars - 11/9/2003 12:21:34 AM
Ed Smith
Status: offline
Believe me, the set screw IS a standard size, imperial or metric. It is a case of getting the correct size hex key.
"c" clips are 'C' shaped clips that click into a circular slot cut around diameter of a circular rod. If the slot is cut too deep the clips will fall out, if not deep enough they will break while trying to force them in.
Ed S
< Message edited by Ed Smith -- 11/8/2003 7:22:00 PM >
(in reply to redbear)
       Post #: 8
RE: wheel collars - 11/9/2003 4:09:25 AM
redbear
Status: offline
They may all a standard size but they don't always if my standard wrenches.
(in reply to Ed Smith)
       Post #: 9
RE: wheel collars - 11/9/2003 9:07:07 AM
patternwannabee
Status: offline
For those who insist on using wheel collars, here's a tip that could be helpful:
Replace the setscrew with a regular hex head cap screw. That way you can really torque down the wheel collar and it won't come off unless you want it to. No need for threadlocker, yet easily removable.
For 5/32" collars, a 6-32 screw fits. For 1/16" collars, 4-40 screw fits. You can get 1/4" lengths at Micro Fasteners, or just dremel them to size.
It'll add a little weight, but you'll never lose a wheel again.
Must admit, tho' I like the c clip idea. Have to give it a try.
       Post #: 10
RE: wheel collars - 11/9/2003 9:42:56 AM
Countryboy
Status: offline
The only thing the wheel collar is good for is to act as a fence for cutting the groove with the dremel. To get a perfectly cut groove, place the wheel collar on the axle so that the outer edge is at the point that you want the c-clip to be, then tighten the set screw in the collar. You now have a perfectly square fence to let the cut off wheel rest against while you cut the groove.
       Post #: 11
RE: wheel collars - 11/9/2003 12:31:16 PM
Mike in DC
Status: offline
quote:
ORIGINAL: redbear
I agree with Ed that the screws are standard sizes, but I have had the same experience with the stripping. My conclusion is that not all wheel collars are alike, and some just have cheap crummy set screws (too much slop). Usually you can replace them with either good set screws, or hex head cap screws. At the tiny sizes, the screw should be really really snug on your allen wrench.
       Post #: 12
RE: wheel collars - 11/9/2003 1:03:59 PM
SeacretsOceanCity
Status: offline
Do you mean snap ring. In the shape of a C with a hole at each end? And you would use snap ring pliers to install and remove, is this right?????
www.seacrets.com
       Post #: 13
RE: wheel collars - 11/9/2003 2:04:48 PM
DBCherry
Status: offline
512,
I'm pretty sure that's what he's talking about.
I buy good quality wheel collars and haven't had any trouble with either getting them to stay on or with stripped set screws. Of course, you also need good quality hex wrenches! Some of the less expensive hex keys round off a little and cause the screw to strip.
Dennis-
He who dies with the most toys is, none the less, still dead.
(in reply to SeacretsOceanCity)
       Post #: 14
RE: wheel collars - 11/9/2003 11:11:55 PM
jerry dotson
Status: offline
I use a cotter pin for retaining the wheel. Take a torch and heat the very end of the landing gear orange hot and slowly remove heat and brush it back and forth to slow the cooling process. Use a wet rag or any thing to make a heatsink so you only anneal the last 1/4 inch or so. Then drill a hole in the gear for a small cotter pin.
(in reply to DBCherry)
       Post #: 15
RE: wheel collars - 11/10/2003 7:58:14 PM
VApr
Status: offline
I usually crank the set screw down just before the set screw dfeels like it will strip and then add a drop of CA in the gap of the collar and axle. Viola! Have not lost a wheel yet!
(in reply to jerry dotson)
       Post #: 16
RE: wheel collars - 11/11/2003 1:46:17 AM
LearjetMech
Status: offline
I think they are actually called "E" clips!!
(in reply to VApr)
       Post #: 17
