RE: RE: Brett Green on modelling the Messerschmitt Bf.110
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: RE: Brett Green on modelling the Messerschmitt Bf.110
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/2/2004 3:43:03 PM
NE0
Status: offline
What? You mean you're not back workin' on the SBD? Shame!
Tom
_____________________________
www.tompierce.net
(in reply to Tmoth4)
       Post #: 101
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/2/2004 5:54:33 PM
Tmoth4
Status: offline
Soon, Tom...very soon!
I thought I'd have this thing in primer already but it's taking longer than I thought. Come to think of it EVERY plane I've built has taken longer than I thought!...that have a familiar ring to it?
Jim
(in reply to NE0)
       Post #: 102
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/2/2004 7:39:19 PM
NE0
Status: offline
Hmmm... about that taking longer than expected... what could you possibly mean? Boy that never happens to me.
Tom
www.tompierce.net
       Post #: 103
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/11/2004 2:33:52 PM
Tmoth4
Status: offline
I cut away the bottoms of the nacelles. The removed parts will be used as forms for making fiberglass doors.
Jim
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
"I'm TRYIN' to think...but nothin' happens!!"
(in reply to NE0)
       Post #: 104
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/11/2004 8:42:41 PM
Falcon Jet
Status: offline
Jim,
Looking great! What did you use to cut out the gear doors with? I'm guessing a dremel with a cutting wheel? Getting ready to cut out the nose gear door on a P-38 soon, any tips on do's and don'ts?
Chris.
       Post #: 105
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/11/2004 10:00:37 PM
Tmoth4
Status: offline
Chris,
I used a #11 x-acto to make a score line in the glass layer, then cut with an x-acto handle with a keyhole saw blade in it. I have a better description at the rcscalebuilder.com site under Don Smith plans.
Jim
(in reply to Falcon Jet)
       Post #: 106
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/22/2004 2:19:37 AM
Tmoth4
Status: offline
I'm making the gear doors by using the cutout shells as forms. that way I can make more if I have to. I first covered the forms with monokote and then waxed them with a couple of coats of car wax. Here are the epoxy/glass layups on the forms and then after being removed. I used a butter knife and an old hacksaw blade to work them loose. They were still a little too flexible so I'm putting another layer of epoxyglass on.
Click for fullsize
Click for fullsize
       Post #: 107
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/22/2004 2:29:20 AM
Tmoth4
Status: offline
Hatches are being made in the upper nacelles for access to the fuel tanks and throttle servos. After cutting them out I made formers for the ends of them by tracing the inside curves. The front, rear, and edge faces will be surfaced with 1/64 ply for more durability.
Jim
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 108
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/22/2004 2:51:49 PM
Falcon Jet
Status: offline
Looking great Jim, that's a cool idea you have. Will you be putting in "false" frame work on the inside of the gear doors as well? That will definately give them strength. Can't wait to see your finished product!
Chris.
< Message edited by Falcon Jet -- 2/22/2004 10:07:41 AM >
       Post #: 109
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/22/2004 5:34:52 PM
Tmoth4
Status: offline
Thanks, Chris. Yeah, I'm going to do something to stiffen the gear doors. The full-size one has a thickness to them with an inner shell. I'm going to do something like that...maybe a few former and balsa skin on the insides.
Jim
       Post #: 110
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/22/2004 6:13:33 PM
Falcon Jet
Status: offline
Keep us posted Jim, anxious to see how they come out.
Chris.
       Post #: 111
RE: RE: Brett Green on modelling the Messerschmitt Bf.110 - 2/25/2004 1:28:31 PM
Tmoth4
Status: offline
I test ran the engines the other day. They are 33cc Homelite chainsaw conversions, and are smooth powerful little engines. Running them both at the same time I was pleasantly surprised at how little vibration there was.
Click for fullsize
Click for fullsize
       Post #: 112
RE: Brett Green on modelling the Messerschmitt Bf.110 - 5/10/2004 3:56:09 PM
Tmoth4
Status: offline
Update on Bf110. Got it all primed and applied panels edges. The wether has improved and I finally got to put some paint on it.
Jim
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 113
RE: Brett Green on modelling the Messerschmitt Bf.110 - 5/10/2004 3:59:19 PM
Tmoth4
Status: offline
Here's the second color on the top and sides. One more color (RLM70) go on top in a "splinter" pattern, then it will be ready for markings.
Jim
Click for fullsize
Click for fullsize
       Post #: 114
