MY 1/5 SCALE GOES CRAZY NEED *HELP*
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> MY 1/5 SCALE GOES CRAZY NEED *HELP* Page: [1]
Login
MY 1/5 SCALE GOES CRAZY NEED *HELP* - 11/8/2003 12:42:12 AM
sharkov
Status: offline
MY FIRS CAR WAS 1/6 FG BEATLE. AND EVERY TIME I STARTED THE ENGINE IT SEEMS LIKE IT HAD AN EFFECT ON MY RECEIVER BECASE THE CAR JUST WENT CRAZY.I PUT A FAIL SAFE AND IT HELPED BUT ONLY WHEN THE CAR WAS ABOUT 30 FEET OR LESS.
NOW A HAVE A BERGONZONI BRAVE WITH FAIL SAFE AND HAVING THE SAME PROBLEM.
DOES THIS TYPE OF ENGINE HAS AN EFFECT ON THE RECEIVER?
DO I NEED A BETTER BATTERY PACK?
HELP ** PLEASE**
< Message edited by sharkov -- 12/15/2003 4:37:56 PM >
       Post #: 1
RE: MY 1/5 SCALE GOES CRAZY NEED *HELP* - 11/8/2003 1:08:03 AM
remten2001
Status: offline
what set up are you running?radio type?batteries?servos?receiver?failsafe?
(in reply to sharkov)
       Post #: 2
RE: MY 1/5 SCALE GOES CRAZY NEED *HELP* - 11/8/2003 1:23:59 AM
drevil
Status: offline
Where, and how do you have the receiver mounted?
What kind of radio is it? From what i've heard AM radios get alot of interference from these motors so a FM or PCM radio is recommended. I'm using an airtronics MX3 FM radio system without any problems.
I have my receiver wrapped in a balloon (for waterproofing) on a piece of foam rubber for shock vibration. A reciever that is mounted directly on a solid surface in a gas car can get glitchy. You also need to make sure your antenna isnt rubbing on anything metal which could also cause glitches.
If you are using a good radio system, and have everything mounted right then i'd say that either there is something wrong with the radio system itself or you could possibly have a bad set of crystals. I've known more than a few people who have had bad crystals, or crystals with a frequency that get interference/glitching from something locally.
Hope that helps
Mike
(in reply to remten2001)
       Post #: 3
RE: MY 1/5 SCALE GOES CRAZY NEED *HELP* - 11/8/2003 3:19:37 PM
volsstd
Status: offline
Do you have that cap over the sparkplug? Here in RED
(in reply to drevil)
       Post #: 4
RE: MY 1/5 SCALE GOES CRAZY NEED *HELP* - 11/9/2003 12:52:36 AM
sharkov
Status: offline
thnx guys.
< Message edited by sharkov -- 11/14/2003 11:15:26 PM >
       Post #: 5
RE: MY 1/5 SCALE GOES CRAZY NEED *HELP* - 11/9/2003 3:38:51 AM
bush87
Status: offline
I have seen problems with spark plugs, Some are none resistor . Also make sure the antenna is not close to the spark plug when your running. Hope this will help. bush87
       Post #: 6
RE: MY 1/5 SCALE GOES CRAZY NEED *HELP* - 11/10/2003 8:45:01 PM
drevil
Status: offline
Glad to help!
(in reply to bush87)
       Post #: 7
RE: MY 1/5 SCALE GOES CRAZY NEED *HELP* - 11/11/2003 7:57:13 PM
HondaCRX
Status: offline
are you using a plastic control rod on the throttle? the metal ones pick up the ignition and glitch the radio
_____________________________
Mazda RX-7
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
