FLYBOY
Joined: 1/7/2002 From: Missoula, MT, USA Status: offline
If you want to make money, stay away from the blimp idea. Ours is 12 feet long, takes a fortune in helium to fill, and you have to keep it light, so you can't take much more than business cards up to drop. We drop tiny stuffed bears once in a while, but we put small helium filled balloons on them to hold them up, and hook a ribbon to them and drop the tow cord and they are filled so they just sink. The balloon won't take much weight, and if you put a bunch on and drop it, your blimp goes to the ceiling. It is a ton of fun and we fly pre game and half time in a huge arena. It takes a crew of at least two and most times three to fly it, fill it, load it, get it read and all that, and then you have to store it, full hopefully so you don't have to re-fill it every time. That gets expensive. I think Pony makes ours, the envelopes are just over $1000 and we use a new one about every year because in order to make the material light enough to lift, it has to be thin, and it gets a lot of holes in it. Just touching a light or ceiling tile will put pin holes in it. Have a blast. It is fun, but the cost is way higher than they will pay for it.
_____________________________
Fly it till the wings come off.
