RE: WORLD MODELS 80in. ZERO
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: WORLD MODELS 80in. ZERO
Page: <<   < prev  1 2 3 4 5 6 7 8 [9]
Login
RE: WORLD MODELS 80in. ZERO - 3/1/2007 6:11:31 PM
Capt G
Status: offline
Greg - the book says 152mm (5.98" from firewall to thrust washer. G. (sent you a link - cheaper and more scale?)
(in reply to Hellcat716)
       Post #: 201
RE: WORLD MODELS 80in. ZERO - 3/5/2007 3:20:03 PM
Eric.Henderson
Status: offline
I was wondering how far the cowl (and thus the engine) can be moved forward? I have almost an alergic reaction to adding lead!
In particular I am looking for the dimension from the firewall to the front of the cowl opening. Can anyone easily measure that for me please?
Regards,
Eric.
quote:
ORIGINAL: p39
I used the 85 degree gear. The distance from the firewall to the backplate isn't set in stone and can actually be used to balance the plane. I used a Fox 2.4 and have the backplate nearly even with the front of the cowl. There is some fudge room for sliding the cowl back or forward too. I balanced my plane that way so I didn't have to add any nose weight.
_____________________________
If it has wings I''ll fly it....
(in reply to p39)
       Post #: 202
RE: WORLD MODELS 80in. ZERO - 3/5/2007 3:35:41 PM
p39
Status: offline
The cowl mount isn't pre-set. You can adjust that depending on your motor/balance point. The cowl slides back and forth. Unlike a yak or sukhoi where it butts on the front of the fuselage.
(in reply to Eric.Henderson)
       Post #: 203
RE: WORLD MODELS 80in. ZERO - 3/16/2007 7:09:40 PM
operator 88
Status: offline
MR pettit I know you built your world model zero a time ago ,but i on the otherhand started yesterday would inform me, being a novice at this at the ripe old age of 68 how did that G38 mount up for you? I have a motor thats not the newest , it has the cup mount and long steel prop shaft, could that combo be my problem?Do change them, or rebuild the motor mount? thanks if you can help.BillR
(in reply to pettit)
       Post #: 204
RE: WORLD MODELS 80in. ZERO - 3/16/2007 8:00:54 PM
Doolittleraider
Status: offline
I have G-45 and was considering it for the WM Zero has anybody done this set up?
thanks
Peter
"No Mission is routine."
www.doolittletokyoraiders.com
(in reply to ultraeast)
       Post #: 205
RE: WORLD MODELS 80in. ZERO - 3/18/2007 12:41:45 AM
Ron101
Status: offline
Hey Peter,
I don't know if this will help but,
I have a zdz 40 in mine it weights 2.86 pounds I have a ton of nose weight.. it flys great
The G-38 weights 4.43 pounds and with good batt. placement can balance out.. I flew with one and it seemed almost as fast as mine
The G-45 weightd 4.93 pounds ... I would bet if you did the ignition conversion and maybe used a two RX batt back far you would come out golden... I know it would pull like crazy.. and be a great set up...IMHO
good luck
Ron
"It''''s not personal, Sonny. It''''s strictly business."
(in reply to Doolittleraider)
       Post #: 206
RE: WORLD MODELS 80in. ZERO - 3/30/2007 6:38:11 PM
blubberse
Status: online
Hi! Long distance call from sweden! I know it might be a little bit too late but early on in this thread there was a question about Saito 170 and if it will fly with this engine..Well,this is the second flight with my TWM Zero yesterday and I hope the file isn`t too large (39 MB) but we dont want to compress it too much.. The plane flies nice but i will order an other propp for it,this one is a MA 18X6 and i am going to try with 18X8
to get the RPM down a little bit and perhaps add some speed..
Thanks Kelvin för the exhaust sytems I bought from you,the sound is awsome ,they are THE BEST!!
http://www.junkshop.nu/flyg/bokis_20070329/twm_zero_170r3_big.wmv
(in reply to Ron101)
       Post #: 207
RE: WORLD MODELS 80in. ZERO - 7/31/2007 2:07:02 AM
Zippi
Status: online
I can't seem to find a price on TWM Zero. Anyone have a URL that has a price?
"It Ain''''''''t Lookin Good"
http://zippi.50webs.com/index.htm
(in reply to blubberse)
       Post #: 208
RE: WORLD MODELS 80in. ZERO - 7/31/2007 4:15:39 AM
moto-x
Status: offline
Hey Zippi, Airborne models has the 80 inch zero for 449.99. Go to www.airborne-models.com.
It's about to get real ugly.
(in reply to Zippi)
       Post #: 209
RE: WORLD MODELS 80in. ZERO - 8/1/2007 2:28:09 AM
Zippi
Status: online
quote:
ORIGINAL: moto-x
Thanks dude. That URL is no good. Here it is http://www.airborne-models.com/Index.asp
(in reply to moto-x)
       Post #: 210
RE: WORLD MODELS 80in. ZERO - 8/1/2007 2:41:43 PM
NoFlaps
Status: offline
I picked up a used one of these from a buddy of mine.
You'll see that I repainted her in Imperial colors, added a 1/2 cockpit, guns, and plenty of weathering.
It was a great flying plane but the retracts are not so good.
I had century Jet make some for new LG for me (see crashed image for struts.
Unfortunately I cashed her yesterday...I think I had a battery failure and simply had no controll over the plane.
There's nothing salvagable, but some good memories.
Engine was a Zenoah, G45 and she was a rocket!
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by NoFlaps -- 8/1/2007 2:45:07 PM >
Any landing you can walk away from is a good one.
(in reply to bladebender)
       Post #: 211
RE: WORLD MODELS 80in. ZERO - 8/2/2007 5:53:53 AM
Hisham
Status: offline
Ouch,
Sorry for the loss....
Mine is assembled and ready for the test flight,
hope this weekend... am using a G38 + dual switches and batteries.
Hisham.
Scratch building is my Way of life.
(in reply to NoFlaps)
       Post #: 212
Jump to:
