Mixing different fuels
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Mixing different fuels
Page: [1]
Login
Mixing different fuels - 11/10/2003 2:14:40 PM
a68fan
Status: offline
Before I ruin any engines, or waste a gallon a fuel, I have a question..
I have a gallon of relativly fresh 30% Byron heli fuel, and about 1/2 gallon of Cool Power 15%.. Can I mix these two together to run in airplane engines?? (Evolution .46 & Saito .72's)
       Post #: 1
RE: Mixing different fuels - 11/10/2003 9:55:42 PM
ShoestringRacer
Status: offline
Yeah you can mix them without hurting anything. It will bring the nitro down below 30% but that doesnt really matter. It wont go down much if you are adding only 1/2 gal of 15%. You could mix them or just use one after the other runs out. Your call.
(in reply to a68fan)
       Post #: 2
RE: Mixing different fuels - 11/12/2003 3:03:24 PM
a68fan
Status: offline
Thanks!!
(in reply to ShoestringRacer)
       Post #: 3
RE: Mixing different fuels - 11/12/2003 3:16:28 PM
jessiej
Status: offline
You will have about 25% nitro.
       Post #: 4
RE: Mixing different fuels - 11/13/2003 3:42:57 AM
Sport_Pilot
Status: online
22.5% nitro.
(in reply to jessiej)
       Post #: 5
RE: Mixing different fuels - 11/13/2003 5:38:47 PM
Jim Thomerson
Status: offline
Show your work or you get no credit for your answer.
Jim
(in reply to Sport_Pilot)
       Post #: 6
RE: Mixing different fuels - 11/13/2003 6:34:41 PM
scole
Status: offline
128*30+64*15=4800/192=25%
(in reply to Jim Thomerson)
       Post #: 7
RE: Mixing different fuels - 11/14/2003 3:26:28 AM
Sport_Pilot
Status: online
(15%+30%)/2=%22.5
(in reply to scole)
       Post #: 8
RE: Mixing different fuels - 11/14/2003 12:52:41 PM
vinnie
Status: offline
quote:
ORIGINAL: scole
I'm going with scole !
_____________________________
Regards,
vinnie
AMA 680367
(in reply to scole)
       Post #: 9
RE: Mixing different fuels - 11/14/2003 5:37:05 PM
hauckf
Status: offline
Byron lists the percentages in their fuel by weight, not by volume like every other fuel manufacturer. Byron's "30%" nitro, "24%" oil Heli fuel actually contains a little over 24% nitro and 22% oil by volume. Mixing 1 gal of the Byron "30%" Heli and 1/2 gal of 15% Cool Power will result in a fuel with about 21% nitro and 20.5% oil. (If Byron's percentages were by volume, Scole's calculation would be correct.)
(in reply to vinnie)
       Post #: 10
RE: Mixing different fuels - 11/14/2003 6:37:13 PM
Sport_Pilot
Status: online
I think scole is mixing all of the fuel together. I would have simply added the 30% to the 15%. Modifying my calculation for mixing both together then would be (.5*15%)+(1*30%)/1.5=25%. No need to use ounces, simpler to use the largest known volume which is a gallon.
       Post #: 11
RE: Mixing different fuels - 11/14/2003 8:37:30 PM
Bax
Status: offline
One precaution about mixing model fuels. If they're both fresh, there should be no effects at all, other than the change in total nitro percentage. If one of the fuels is old, and hasn't been stored as well as it should, it may contain moisture, which will only contaminate the resulting mix. Moisture in model fuel causes hot running, bad idle, and bad acceleration. You may wind up taking some perfectly good fuel and mixing it with stuff that will result in you having nightmares trying to get your engines to run well.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
Search | Marketplace | Event Calen
