RysiuM
Joined: 4/22/2003 From: Elk Grove, CA, USA Status: offline
Capitan, Let me add my 2 cents. 1. When you run gas-glow fuel the mix must be richer, than running just gasoline. My Zama carb that came with Poulan 25cc can not deliver enough fuel for that even when both needles are wide open. It can be tuned easy on gasoline, but more than 10% methanol in the fuel makes the mixture always to lean. This is the reason why I run gas/glow with 6:1 ratio and glow plug powered all the time. 2. This happened already twice. One day my engine did not want to run. I opened the carb and found some kind of gel/goo on the internal filter. Easy to clean tho. And the final note, all my gas-glow engines run kind of funny making sound like missing every second or so. But they run very stable with good transition and reliable low idle. I'm not sure why is that missing sound, but it is only in the air when plane is flying. On the ground they run without missing a bit. Changing the mixture does not make this sound go away. I just used to live with that.
_____________________________
Mather Aerospace Modelers, Inc. AMA Gold Leader Club, Charter #1243, Sacramento, CA
