RE: gas fuel with glo plug no ignition    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: gas fuel with glo plug no ignition
Page: <<   < prev  88 89 90 91 92 93 94 95 [96] 97   next >   >>
Login
RE: gas fuel with glo plug no ignition - 3/27/2009 2:53 AM
RysiuM
Last Login: 3/11/2013
Status: offline
quote:
ORIGINAL: john_kb7nrn
So, does the gas/glow plug only system work?
Yes, it works for me. Glow plug powered all the time from single cell Sub-C NiMh (3700mAh). I run Poulan 25 and ASP 61 (modified to fit Walbro carb). The first one is in my CoroCub the other in SPADET. Spadet gets almost 25 minutes of flying from 11cc fuel tank.
And I forgot to mention, use gasoline-oil mix (without methanol).
< Message edited by RysiuM -- 3/27/2009 3:35 AM >
_____________________________
Visit my site at www.rysium.com
Hide Signatures
(in reply to john_kb7nrn)
       Post #: 2376
RE: gas fuel with glo plug no ignition - 3/27/2009 4:02 AM
john_kb7nrn
Last Login: 4/1/2009
Status: offline
av8tor1977,
I'm staying away from the gas/glow fuel mix because it's not convienent for me and it's more expensive. I know, you only use 1/3 glow fuel to the gas. I also have to drive 35 miles to the LHS and they don't carry the Super Tiger fuel needed.
If RysiuM is using regular gas/oil mix with a glow plug, then I'll try that. " use gasoline-oil mix (without methanol)"
The idea is to lighten up the motor but use what's easy to get and relativly inexpensive.
Right now, I've been using 100 octane avgas and Lucas semi-synthetic oil at 50:1. Burns very clean with no smoke and little smell. Together, the gas oil mix is costing me $5.50/gal.
Hide Signatures
(in reply to RysiuM)
       Post #: 2377
RE: gas fuel with glo plug no ignition - 3/27/2009 4:44 AM
trumpetman
Last Login: 5/17/2013
Status: offline
I like E-85 and a 3 oz on board glow. My current fuel cost is: 1.85\gal. E-85 and 1.78 for Cool Power green.
5 oz. for 25:1. You do have to buy a quart (32 oz) for about 11.00. That's 3.68 and the power is great.
Mac 28 (mods) on a 18X6W gives 8000 rpm. Bowman ring not broken in yet.
Jack
Hide Signatures
       Post #: 2378
RE: gas fuel with glo plug no ignition - 8/23/2009 3:14 PM
rexbirk
Last Login: 5/18/2013
Status: offline
Any updates on this project? Does it work long term?
Rex
Is being a Circle Flyer a bad thing?
Rex Birkinbine
Hide Signatures
       Post #: 2379
RE: gas fuel with glo plug no ignition - 8/23/2009 8:22 PM
av8tor1977
Status: offline
I'm still flying it with great success. Was just out yesterday and flew multiple trouble free flights with my Giant Stik with a twin cylinder 48cc engine running Gas/Glow. Easy starting, better power, slow idle, etc. Works for me...
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to rexbirk)
       Post #: 2380
RE: gas fuel with glo plug no ignition - 8/23/2009 9:26 PM
fujiman
Status: offline
HI PEOPLE. I have an ops 60cc flat twin glow eng. how do you think it would fare on gas/glow? 30cc per cyl. fuel ratios recommends???? any help would be apprec. thanks, fujiman CAUTION! FLY IN THE MIDDLE OF THE AIR, NOT NEAR THE EDGES
Hide Signatures
(in reply to av8tor1977)
       Post #: 2381
RE: gas fuel with glo plug no ignition - 8/28/2009 10:22 PM
tjbv
Last Login: 1/10/2013
Status: offline
xryij
Hide Signatures
       Post #: 2382
RE: gas fuel with glo plug no ignition - 8/28/2009 10:35 PM
av8tor1977
Status: offline
Fujiman: Check here: http://www.rcuniverse.com/forum/m_8009384/mpage_1/key_/tm.htm
AV8TOR
Hide Signatures
(in reply to tjbv)
       Post #: 2383
RE: gas fuel with glo plug no ignition - 9/10/2009 8:25 PM
captinjohn
Status: offline
DLE 30cc....my conversion engines are going BYE BYE Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 2384
RE: gas fuel with glo plug no ignition - 10/13/2009 9:52 PM
Dinkster
Last Login: 10/23/2009
Status: offline
Hey Guys,Im back! havent got to get on here in awile,Mabie a year but was going through a devorce.I did get my planes lol.I had to find this page again took me a little wile sence the wife does have the old computer.I got to fly my 1/4 cub with 25cc gas/glow not to long ago,Had a bad wind when I got over the tree line come up blew over and crashed.The good thing it was just front end damage,And its almost back together.One thing I forgot all about is my prop,Ineeded to change it to abt 2 size's larger.I guess from not messing with it so long I forgot about it,and no internet then.I remember alot of you guys helping alot of people on here.Now I get to go back on the pages I missed out on.Thanks Guys!
Hide Signatures
(in reply to captinjohn)
       Post #: 2385
RE: gas fuel with glo plug no ignition - 7/16/2010 2:38 PM
RysiuM
Status: offline
I found one bad thing about the gas-glow fuel mix at least with the oil I used. The fuel separated and created a small flakes of something that clogged the carb. I wanted the engine trouble free so I changed to gasoline only. So I was running my Poulan 25 on Gasoline/oil mix with glow plug that was powered all the time. I lost some power comparing to gas-glow fuel mix but no more problems with fuel separation.
The bad thing that the engine did not sound "clean" - regardless of the mixture setting it made the sound like always to rich. I did not have a clue how to fix it until I think I found the problem few weeks ago. Poulan 25 originally has ZAMA carburetor with 7 mm throat. For the sake of experiment I replace it with WT322 that has 9.54mm throat. That was it. The engine runs clean and gets 1500 rpm more. Still on gasoline-oil mix with glow plug powered all the time.
Hide Signatures
(in reply to Dinkster)
       Post #: 2386
RE: gas fuel with glo plug no ignition - 7/17/2010 7:29 PM
w8ye
Status: offline
You should be able to use up to a 11mm carb in the 25cc engine
But if it is running good with what you are using the I would leave it alone.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 2387
RE: gas fuel with glo plug no ignition - 7/22/2010 3:36 AM
captinjohn
Status: offline
Hey Guys...I met a guy that has a Supertiger 3000.  He could never get ti to run right untill he tried L85 gasoline with a O.S. Max "F" glow plug.  He pours 18 oz Klotz oil in a gallon jug...the rest L85 gas.  I could not hardly believe how good that engine ran!  He had it on a good sized war bird!    Capt,n
Hide Signatures
(in reply to w8ye)
       Post #: 2388
RE: gas fuel with glo plug no ignition - 7/22/2010 4:23 AM
spaceworm
Status: offline
Hi capt'n,
That works out to about 7:1 gas to oil. Does the ST 3000 need that much oil, or is it just because it is on gas instead of glow fuel? Was the Klotz the Super Techniplate with synthetic AND castor? I read where it will mix with both gasoline and methanol. I guess when they say methanol they also include ethanol??
I have a Rhino (made by Cox for their Beaver chainsaw) that came to me with no ignition, but with a glow plug adapter. I want to try it with gas-glow or just methanol and no gas, and with Klotz oil. Whadya all think?
Richard
Hide Signatures
       Post #: 2389
RE: gas fuel with glo plug no ignition - 7/30/2010 6:45 AM
lauterbacher
Last Login: 10/10/2010
Status: offline
Has anyone tried the Gas / Glow setup with a Saito 125 4-stroke.
< Message edited by lauterbacher -- 7/30/2010 7:29 AM >
Hide Signatures
(in reply to spaceworm)
       Post #: 2390
RE: gas fuel with glo plug no ignition - 7/30/2010 7:09 AM
gkamysz
Last Login: 2/6/2012
Status: offline
Enya anyone?
http://www.enya-engine.com/180XGS_E.html
Greg
Hide Signatures
(in reply to lauterbacher)
       Post #: 2391
RE: gas fuel with glo plug no ignition - 7/30/2010 10:11 AM
bogbeagle
Status: offline
Interesting Enya. Any more details?
Hide Signatures
(in reply to gkamysz)
       Post #: 2392
RE: gas fuel with glo plug no ignition - 7/30/2010 11:00 AM
aero nut
Last Login: 4/1/2013
Status: offline
Hey Bob (Avi8tor)!
see how far our works has reached!!!! to me this is kind of a certain recognition to our work, finally GAS/GLOW is going INDUSTRIAL and is finally recognized as an alterbnative by the industry.
Hide Signatures
(in reply to bogbeagle)
       Post #: 2393
RE: gas fuel with glo plug no ignition - 7/30/2010 11:01 AM
w8ye
Status: offline
If you read the details in the link, the 180 Enya is sold as a Gas/glow engine which is the title of this thread.
They use a Special chemosyntheses oil to perpetuate the action of the glow plug ?
< Message edited by w8ye -- 7/30/2010 5:11 PM >
Original AMA #31261
Hide Signatures
       Post #: 2394
RE: gas fuel with glo plug no ignition - 7/30/2010 11:41 AM
bogbeagle
Status: offline
Fiendishly clever, those Japanese. And the oil is only $500-a-gallon!
Hide Signatures
(in reply to w8ye)
       Post #: 2395
RE: gas fuel with glo plug no ignition - 7/30/2010 2:27 PM
av8tor1977
Status: offline
AERONUT Please check your PM's and e-mail me.
Thanks buddy,
AV8TOR
Hide Signatures
       Post #: 2396
RE: gas fuel with glo plug no ignition - 7/31/2010 6:37 PM
cajun1
Last Login: 11/12/2012
Status: offline
I am still unable to find a glow plug adapter to fit a glow plug in my RCGF engine that uses a 10 MM spark plug. I am not a machinist and don't have machine tools, so making one is out.
Anyone know of a source?
I would really like to run the 20 cc engine on gas/oil using full time glow.
CAJUN
FROM DEEP IN THE HEART OF EAST TEXAS PINEYWOOD
Hide Signatures
       Post #: 2397
RE: gas fuel with glo plug no ignition - 7/31/2010 7:52 PM
w8ye
Status: offline
The problem is the there is not enough difference in size to be able to make a reliable adapter
Original AMA #31261
Hide Signatures
(in reply to cajun1)
       Post #: 2398
RE: gas fuel with glo plug no ignition - 7/31/2010 10:00 PM
captinjohn
Status: offline
quote:
ORIGINAL: cajun1
Get in touch with Antique (Ralf)  he did have them.
Hide Signatures
       Post #: 2399
RE: gas fuel with glo plug no ignition - 8/1/2010 11:55 PM
fujiman
Status: offline
cajan 1, i,m going to send you a priv. mess. concerning your need for 10mm plug adapters. thanks, fujiman
Hide Signatures
       Post #: 2400
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: gas fuel with glo plug no ignition
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
