rcairplanenut
CO, USA Status: offline
I typically build only one of each type of model, building molds for a RCM Gitano (some one else design) would be a waist of time for me. I have found it is equal to the weight of a built up former/stringer/skin/balsa block turtle deck (the foam is also hot wired on the inside maintaining a ½” thickness). The weight of that red shell in the picture is 4 oz. NOT pounds. The whole purpose of this thing is for scratch builders that want to have an easier time building turtle decks on one time only builds for a particular design. E-glass over foam is the way Rutan built the Long Eze, that is what I am referring to. I plan on building a mold for the whole fuse of the other aircraft, it is my own design, for the purpose of an exact reproducible out side geometry and a low effort to time ratio on the shells. This aircraft is also a prototype, not a production model! I always run my RX antenna inside the fuse, a carbon shell around ½ of it would block the signal. The weight saving benefits of Carbon on a shell that is in close proximity to your RX antenna are not worth a 1000$ crash because of lack of signal ( I have seen this happen, many times)! All my aircraft fly sir, I do not believe in hanger queens! SGG
< Message edited by rcairplanenut -- 6/17/2004 12:27:35 AM >
