lov2flyrc
FL, USA Status: offline
Same happended to me gordon, I took the time to write it again as I really believe this is important.... Sport_pilot and all, Here in-lies the problem; we have many just like yourself that make assumptions without taking the time to educate yourself beforehand. I am sorry if I came off arrogant; perhaps I let my anger take control yesterday. Let me take a few moments to explain some things…. The waiver as it is called in much more like a certification. It is called a waiver because the AMA by-laws stated the use of turbine engines as a power plant was prohibited. When turbine technology became mainstream, the ama needed to find a way to allow turbine operations to fall under the ama insurance umbrella. Because operating these types of engines required a bit more skill, understanding and safety, the ama developed the waiver process to assure that any individual that wished to operate a turbine aircraft had the knowledge and skill-set required to do so. Currently, any individual that wishes to obtain a waiver will need to demonstrate his flying skills in front of two CD’s, one being a turbine cd (TCD); an individual certified by the ama and jpo to perform a “check ride” much like a full scale examiner (I am one of these TCD). In addition to the “check ride”, the individual must take a ground school and a written exam that is scored by the AMA. Flight performance must be assed using a high speed complex aircraft (should have flaps, retracts etc…) and there are specific maneuvers we will want performed and the pilot must show he is in control of the aircraft at all times. As you can see, this will eliminate many individuals from obtaining a waiver whose skill set is not quite ready for these high performance aircraft. In addition to flying skills, they are instructed to how to properly operate their turbine engine, taught how to properly shut the engine down in an emergency and proper installation and setup techniques. Do you know any other facet of this hobby that has such a demanding process just to be able to fly these types of aircraft?? Please, I beg all of you to educate yourself before jumping to conclusions, jet pilots are some of the safest operators of RC aircraft, and our history reflects that! It is not the speed which kills; it is the recklessness of those behind the sticks! Keep in mind, the two most recent fatalities in RC was from a 40 size trainer and a .60 size helicopter. As turbine operators we are trained on what to do in emergency situations and our aircraft are equipped to shut down should there be signal loss, how many sport pilots can say the same? I have logged over 575 turbine flights on four aircraft this year alone. Only one was lost (on its maiden) due to hardware (servo) failure. Do I sound unsafe to you? Thanks for listening. Todd
_____________________________
Owner/President: Dreamworks Model Products LLC www.dreamworksrc.com 386-852-4793
