sfaust
MA, USA Status: offline
quote:
ORIGINAL: Sport_Pilot Feel it in the sticks? Maybe you have some psyche ability you need to explain to us? Stick feel? Absolutely! At high speed, the elevator is more authoritative and you can tell by how much 'stick' is required for the required attitude change. As the airplane slows down, the same attitude change requires more elevator input, hence more stick. The difference between the stick inputs can easily be called 'stick feel'. When the airplane is slower, you work the sticks more because you need more control deflection to get the same actions from the airplane. If you get to know your airplane well, you can tell when its nearing a stall based on the stick feel in conjunction with the typical visual and audible clues. For example, if your airplane is trimmed for level at high speed, then you slow it down, you better be holding in some elevator to keep it level. If you had no other clues other than a horizontal line in the sky and trying to keep your airplane on it, you could tell if it was going fast or slow based on the 'stick feel' of the elevator. No input, its going fast. Some elevator held in, its say medium speed. Lots of elevator and mushy response, is slow. As a full scale pilot yourself, I am surprised that you haven't noticed that correlation yourself. No voodoo required.
< Message edited by sfaust -- 11/14/2003 5:50:06 PM >
_____________________________
Stephen
