Jim Branaum
Joined: 10/22/2002 From: Fair Oaks Ranch, TX, USA Status: offline
Bill, You need to lower your level of paranoia as I am not attacking you but pointing out what I happen to see as flaws in your approach. I don't always allow 'merit' to sell what I believe are stupid ideas. Sorry if that offends you. A GOOD pilot can tell you when his model has stalled by the control responsiveness changes. Recall earlier remarks about hand and eye coordination? All I have been trying to tell you is that the environment we have at the pilot's station is significantly different that the one from the pilot's seat of ANY rider scale bird. If you wish to throw lots of money away trying to solve a difficult problem that really does not need a solution, I am NOT going to stop you. Most gyros respond to things other than airframe specific air loads which happens to be what stall warning devices address directly. I don't think your idea of a gain control will work for setting up a remote stall warning indicator, nor do I think many modelers who might need this weak crutch will have the ability necessary to make the correct adjustments as the device is moved from airframe to airframe. I view that issue as the show stopper, but you are clearly more intelligent than everyone else so go for it. In other words, it is YOUR idea, so use your money and make it happen! You have defined the parameters of operation and the resources needed to make it work, so all the problems have been solved. Now, just go build and sell it! When you build your wonderful solve all problems whiz bang, make sure that I can still hear my stall warning when Frank Flightpack is doing a low pass with his nitro piped Patriot and that I can move it from my pocket rocket over powered P-51 to my aerobatic birds without having to get another college education or help from some outside resource in setting it up. Figure out a way to do that and have me still welcome at the fields I visit and fly at, or expect to loose lots of money. Those types of issues (how it can work for ALL everywhere) that most on the AMA EC try to address when the alleged 'battles' have occurred. That is why this IS germane to the thread.
_____________________________
Jim Branaum AMA 1428
