had enough
OH, USA Status: offline
quote:
ORIGINAL: royta What type of driving is your 5 - 7 - 1 setup tuned to scale_only_4_me-RCU? Where do you run at? I've heard that Revelation Raceway is best track near us. I could probably get there in 30 minutes from my house. I'd like to tune my PBS to that track if it is the best. I've heard good things about The Dirt in Hemet, but that's farther than I'd like to drive. I've never raced, but the idea sounds fun. However, my wife will probably kill me since I already have to many hobbies as it is. Thanks. Roy If your just bashing then Nitroaddicts set up might work better for you, since it work well in loose conditions. 5-7-1 is more for a clean wet race track condition Honestly I'm no pro racer, I use that set up because a few guys I race with that are more experianced recomended it for me, and it's what they run in there H7s. The loose rear diff helps prevent the rear end breaking loose to easily, I'm told I don't race my H7 as much as I race 10th scale truck I mostly race at Hot Rod Hobbies or KZ speedway If you're in Corona you should try LPRP (Lake Parris Race Park) also, they race Friday night (if enough guys show), Saturaday and Sunday 2pm. The track is right off Romona express way & the 215 right below Lake Perris Alot of very good 1/8th scale guys there www.lprp.com Cya
_____________________________
Don’t give me your attitude, I already have one
