.61 Pitts Muffler on a Tower .75?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> .61 Pitts Muffler on a Tower .75?
Page: [1]
Login
.61 Pitts Muffler on a Tower .75? - 11/13/2003 6:24:48 PM
Zzyzxx
Status: offline
Just spoke to support as to why the .61 Pitts Muffler recommended with the Tower .61 wouldn't work on the .75 - restriction was the only answer - Am I just missing something glaring and obvious but couldn't you ream out the exhaust on the muffler to allow for the extra flow?
       Post #: 1
RE: .61 Pitts Muffler on a Tower .75? - 11/13/2003 6:55:42 PM
w8ye
Status: offline
Cavity volume is a bigger issue than back pressure?
I would think though that there wouldn't be enough difference in a 75 to matter too much though?
The Super Tiger 61 and 75 share the same ones though the Super Tiger 90 uses a larger one.
Worse case would be a un explained overheating problem.
Good luck,
Jim
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to Zzyzxx)
       Post #: 2
RE: .61 Pitts Muffler on a Tower .75? - 11/14/2003 1:10:52 AM
Azcat59
Status: offline
You can solve your problem by buying the Slimline Pitts style muffler made for the OS 91FX, and filing the holes in the mounting flange of the muffler just slightly towards the center. It is fairly large capacity, fits the engine well, and the engine runs well with this setup.
Clair
(in reply to w8ye)
       Post #: 3
RE: .61 Pitts Muffler on a Tower .75? - 11/14/2003 4:51:25 AM
Zzyzxx
Status: offline
Awesome - figured someone had worked this out. Appreciate it much!
(in reply to Azcat59)
       Post #: 4
RE: .61 Pitts Muffler on a Tower .75? - 11/14/2003 6:10:07 AM
Volfy
Status: offline
91FX muffler mounting holes are 42mm center-to-center. Tower 75 is 40mm, so stretching 1mm each way should do the trick.
However, the Bisson GMS .76 Pitts muffler should fit the Tower perfectly, since they appear to be virtual twins made by the same engine manufacturer. It's priced at $33.99, whereas the Pitts mufflers for a .91FX is either $43 or $50.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGBL0&P=0
Not available yet though.
Si vis pacem, para bellum.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
