Volfy
Joined: 1/4/2002 From: Houston, TX, USA Status: offline
Done well, tapped mounting will work just fine. The main reason I don't like tapping is that if you ever break a bolt inside a tapped hole, you're up poo-poo creek. You'll have a tough time drilling the stub out because the surrounding plastic or aluminum is way softer than the steel bolt and the drill bit will wander. It's the same reason I prefer thru-bolt mounting for mufflers. If you are going to tap a nylon composite mount, however, be sure not to use a really fine thread like 2-56. The plastic don't have a whole lot of shear strength with that little "bite".
_____________________________
Si vis pacem, para bellum.
