Which Plane for Homelite 25cc??    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Which Plane for Homelite 25cc??
Page: [1]
Login
Which Plane for Homelite 25cc?? - 11/15/2003 5:39 PM
zipnsplat
Score: 100
Last Login: 7/14/2012
Status: offline
I'm looking for a new plane for my homelite 25cc. I've narrowed it down to 2 planes... The H9 Ultra Stick Lite, or the H9 Edge 540. Which do you think would be better? Is the 25cc engine enough power for the edge? Would the engine fit inside the cowl? I don't have the electronic ignition, so I am concerned that the flywheel would keep the engine from fitting inside the cowl. lastly, would weight be an issue for the edge? Thanks for input!
-Zip
Hide Signatures
       Post #: 1
RE: Which Plane for Homelite 25cc?? - 11/15/2003 6:21 PM
rcglert
Score: 100
Last Login: 2/5/2009
Status: offline
Take a look at the thread entitled "what do you have your conversion in?" There are lots of good suggestions in there!
By the way, I have my Homelite 25cc in a Great Planes Big Stik .60. It really gets after it!
Tom
Hide Signatures
(in reply to zipnsplat)
       Post #: 2
RE: Which Plane for Homelite 25cc?? - 11/16/2003 5:26 PM
av8tor1977
Score: 665
Last Login: 5/23/2013
Status: offline
Hi Tom,
I had a Big Stick 60 converted to a low wing with a gasser on it. Finally crashed it due to interference. I'm in the process of rebuilding it. What mods did you make to your Stick for the gasser?
Thanks in advance,
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to rcglert)
       Post #: 3
RE: Which Plane for Homelite 25cc?? - 11/18/2003 6:50 AM
AIRPLANENUTS
Score: 105
Last Login: 5/21/2013
Status: offline
FWIW I wanted to put a Ryobi 31cc in an Ultra Lite Stick, but I read Mike McConville said it needed 2 oz in the tail for a Saito 1.80 (considerably lighter).
Hide Signatures
(in reply to av8tor1977)
       Post #: 4
RE: Which Plane for Homelite 25cc?? - 11/18/2003 6:27 PM
jstanton
Score: 100
Last Login: 5/22/2013
Status: offline
I am building a balsa USA stingray 120. This plane weigh's in at 9 1/2 lbs with 1276 sq. in. wing area. and an 83" wing span. Looks a lot like a Sig Mid Star. I think this plane would make a good option for a Homelite engine
Jim Stanton
Millington, TN 38053
Hide Signatures
       Post #: 5
RE: Which Plane for Homelite 25cc?? - 11/18/2003 6:29 PM
jstanton
Score: 100
Status: offline
Here is a pic of the Balsa USA Stingray 120. I am still in the building process.
Click to see fullsize image.
Click for fullsize
Jim Stanton
Hide Signatures
(in reply to jstanton)
       Post #: 6
RE: Which Plane for Homelite 25cc?? - 11/20/2003 6:36 AM
JimRoss
Score: 100
Last Login: 6/29/2008
Status: offline
I would go with the Ultra Stik. I have a H9 Edge 540 and its too heavy for a 25cc. Wing loading would be too high unless you're running a pipe and large carb on that weedie.
No matter where you go, there you are.
Of All the people I know, you're one of them.
Hide Signatures
       Post #: 7
RE: Which Plane for Homelite 25cc?? - 11/21/2003 6:03 AM
zipnsplat
Score: 100
Status: offline
I ended up ordering a Cermark Pitts. Can't wait! The 25 may not be enough power. If not, I have a 31cc that I could use.
-Zip
Hide Signatures
(in reply to JimRoss)
       Post #: 8
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> Which Plane for Homelite 25cc??
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
