LtDoc
OK, USA Status: offline
FWIW Underwater 'gliders' isn't a new idea, it's been around for quite a while. The major problem seems to be having enough 'depth' for the system to work, and having enough ballast control. It's just like a glider soaring in still air. Point the glider down and you get forward motion and loose altitude. If you could make the glider lighter than air, then tilted it up, you would still get forward motion and an increase in altitude. The same principal works in water instead of air, ~IF~ you have a lot of depth to work with. Lots of ups-n-downs to get the forward motion. As for modulating a magnetic field, while it's certainly possible, it's going to have even a shorter range than using radio frequencies under water. A 'better' solution would be a lower radio frequency (as in VLF), but since there aren't any allocated for RC use, and since the Navy tends to get mad if you mess with 'their' frequencies, I think it's a waste of time. But wouldn't it be fun? - LtDoc
