5925 vs 5975
Tower Hobbies
Logged in as Guest
  Printable Version
Low profile on/off switch with external charging jack
Seller:  k4lpcm
Details:   $19.99   |  9/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> 5925 vs 5975
Page: [1]
Login
5925 vs 5975 - 11/17/2003 3:23:35 PM
xp8103
Status: offline
Ok Mike, faced with an installation where the performance (torque and speed) of either of these servos is more than adequate, which do you choose? The MP gear train which is unbreakable? Or the new Karbonite gear which Hitec doesn't call unbreakable so I assume that it can be broken? They are priced the same. Their respective outputs and speeds are similar enough as to make them indistinct. The metal geartrain is unbreakable thus one would think that its use in a high stress place (giant scale aerobat elevators for example) is a good choice yet the Karbonite gear has essentially no wear so IT would seem a good choice. So which is it?
_____________________________
Nik Rende
AMA 83249
       Post #: 1
RE: 5925 vs 5975 - 11/17/2003 4:57:10 PM
MikeMayberry
Status: offline
What is the size and weight of the plane in question?
Mike.
(in reply to xp8103)
       Post #: 2
RE: 5925 vs 5975 - 11/17/2003 6:01:48 PM
xp8103
Status: offline
Mike,
Honestly, I am asking a hypothetical here; I don't have a specific application in mind. I have 5925s in my 24 pound 33% H9 Sukhoi running on 6 volts. I have 5625s and 5645s on 6v in my Midwest Super Stinker. The Super Stinker comes in around the 15 pound range. Let's say I was considering replacing the servos in either of those planes.
Nik Rende
AMA 83249
(in reply to MikeMayberry)
       Post #: 3
RE: 5925 vs 5975 - 11/17/2003 6:42:10 PM
sizam
Status: offline
Ack, lets say its my 13lb 27% extra?! I just ordered 4 of the 5975's as I thought the karbonite was the way to go, I know the metals are 'unbreakable' but figured the resin would be similarly unbreakable/unstripable, was I wrong? They're certainly lighter which is why swayed me in the first place, that and little to no wear.
"Well you're in your little room, And you're working on something good;
But if it's really good, You're gonna need
       Post #: 4
RE: 5925 vs 5975 - 11/17/2003 6:50:30 PM
xp8103
Status: offline
Bill and Ted,
That was sort of the crux of my question. These servos from a performance standpoint seem to be equals of each other. I was wondering what would make one choose one over the other?
BTW, I think for your application, you have chosen wisely.
Nik Rende
AMA 83249
(in reply to sizam)
       Post #: 5
RE: 5925 vs 5975 - 11/17/2003 8:04:04 PM
MikeMayberry
Status: offline
The Karbonite gears are four times stronger than the standard nylon. So... let's look at the potential limits of this servo if using one per control surface. I would say about a 15lb plane would be the maximum limit and that may be pushing it. Now... let's say you have two servos per surface... the load is now spread beween the two servos so they could be used in an even bigger plane. There has really been no baseline set as to their true limits; they may be perfectly suited for 40% with 3 per aileron and 2 per elevator half. What we might find is that one more servo per control surface is needed so the gears will hold up to hard 3D flying.
Mike.
       Post #: 6
RE: 5925 vs 5975 - 11/17/2003 8:44:58 PM
xp8103
Status: offline
THATS what I was looking for. So if instead I am putting them in a 1/4 scale or 1/3 scale something scale as opposed to an aerobat, we'd be doing ok.
Nik Rende
AMA 83249
       Post #: 7
RE: 5925 vs 5975 - 11/17/2003 9:17:51 PM
sizam
Status: offline
Ah, ok, I guess I guess I feel safe using 5975's (one each) on each aileron and each elevator half, but stick with a 5945 on the rudder.
< Message edited by sizam -- 11/17/2003 4:18:37 PM >
       Post #: 8
RE: 5925 vs 5975 - 11/17/2003 11:47:02 PM
MikeMayberry
Status: offline
That is correct that slow flying planes with smaller control surface throw put much less load on the servo and gears than a 3D type aircraft flown at its limits!
(in reply to sizam)
       Post #: 9
RE: 5925 vs 5975 - 11/19/2003 12:23:50 AM
Geistware
Status: offline
I keep buying gear sets for my servos. If I can have a servo who's gear train doesn't wear out, it is a benefit!
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 10
RE: 5925 vs 5975 - 11/20/2003 6:49:55 PM
hilleyja
Status: offline
Mike,
Wouldn't it also be true to say the Karbonite gears are not as sensitive to developing slop over time that metal gears do?
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
       Post #: 11
RE: 5925 vs 5975 - 11/21/2003 6:17:49 PM
MikeMayberry
Status: offline
The gear wear-- or lack there of-- is the biggest advantage. Our tests showed no signs of wear after 250,000 cycles!
Mike.
(in reply to hilleyja)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
