GWs A10 EDf55's
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> GWs A10 EDf55's
Page: [1] 2 3 4 5 6 7 8   next >   >>
Login
GWs A10 EDf55's - 11/18/2003 9:52:48 PM
gerrymac
Status: offline
Anyone out there found any problems with the GWS A10 on the EDF 55 fans.
I've had to cut a new battery hatch pushing the cells up to the nose, alternative was to add weight.
Anyway I'm hoping I wont have a cool RC Car!
Ger
       Post #: 1
RE: GWs A10 EDf55's - 11/19/2003 4:01:31 AM
A10FLYR
Status: offline
quote:
ORIGINAL: gerrymac
Ger
How could we? The LHS called Horizon the other day and was informed we had 3 more weeks to wait!
_____________________________
Dean,
A10FLYR
(in reply to gerrymac)
       Post #: 2
RE: GWs A10 EDf55's - 11/20/2003 8:25:52 AM
Mhale71
Status: offline
thats one big model in ur avator... fuel or electric?
(in reply to A10FLYR)
       Post #: 3
RE: GWs A10 EDf55's - 11/21/2003 2:50:47 AM
A10FLYR
Status: offline
quote:
ORIGINAL: block head ned
She be burnnin kero. Originally RAM 750s but soon to be usin Yer mate, Chris Mounkley's, new turbines. We have considered electrifing one tho. Shouldn't be to difficult with the new E stuff.
Dean,
A10FLYR
(in reply to Mhale71)
       Post #: 4
RE: GWs A10 EDf55's - 11/21/2003 6:33:22 AM
Mhale71
Status: offline
nice
       Post #: 5
RE: GWs A10 EDf55's - 11/23/2003 3:07:50 PM
SteveR
Status: offline
quote:
ORIGINAL: gerrymac
Ger
Hi Ger,
Just flown my '55. Initially needed all the weight given to balance, but I also needed lots of up elevator to maintain level flight. Second flight, I removed half the weight, better but still needed up trim. I have now taken all the weight out, but put my RX in the nose. Not tried that yet as it is too cold, and the epoxy has still not set (gluing the nose back on)
I do have a little trouble with glitches, though. Might be because I had the RX near the ESC (2" , hence the need to glue the nose back on and move the RX into that section.
The performance was, slight to say the least. Just managed about 20', but rolls were possible with a little run up. Hope the weight saved will improve things.
Steve
       Post #: 6
RE: GWs A10 EDf55's - 12/17/2003 12:38:13 PM
ticketec
Status: offline
What battery pack are you guys using?
I have flown my A-10 with the EDF-55 once in a fair amount of wind and she really struggled to hold altitude( not enought airspeed/thrust to make a turn)
I'm using a 7cell 700mah Ni-mh AAA pack and need to have weight in the nose to balance her out. I was thinking of adding another cell to the pack and taking the extra weight out?
(in reply to SteveR)
       Post #: 7
RE: GWs A10 EDf55's - 12/19/2003 12:18:01 AM
SJN
Status: offline
Im using KAN 1050 8 cell packs.
8cell pack weighs 176 grams
I cant imagine using AAA packs. Even my KAN packs get pretty warm, and they can handle around 18 amps.
CG is right on with these packs.
Motors included in my kit are called EM150G
Flying weight is 650 grams
It flys fine. Deffinatly not overpowered. I think 8 cells is too much for these motors, as I can see lots of sparks from the endbell of the motor at full throttle. 7 cells will make the motors last longer for sure . But I just fly at reduced throttle at the moment.
Im going to upgrade to the EM300H motors as soon as my LHS has them in stock. They should withstand a 9 cell pack.
SJ.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SJN -- 12/19/2003 1:31:54 AM >
(in reply to ticketec)
       Post #: 8
RE: GWs A10 EDf55's - 12/19/2003 12:19:00 AM
SJN
Status: offline
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to SJN)
       Post #: 9
RE: GWs A10 EDf55's - 12/19/2003 12:19:48 AM
SJN
Status: offline
I did a few small mods.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SJN -- 12/19/2003 1:21:55 AM >
(in reply to SJN)
       Post #: 10
RE: GWs A10 EDf55's - 12/19/2003 12:20:52 AM
SJN
Status: offline
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to SJN)
       Post #: 11
RE: GWs A10 EDf55's - 12/19/2003 5:59:21 AM
ticketec
Status: offline
Where can i get these cell from? (I'm From Australia so net-shopper)
Are they 2/3 AA?
I'm a newbie to electric...
(in reply to SJN)
       Post #: 12
RE: GWs A10 EDf55's - 12/19/2003 10:12:03 AM
SJN
Status: offline
G,day mate
Since I live on the opposite end of the world from you , I dont have a clue where you could buy them :-)
Size: 17x30 mm NiMH. (Nikkel-Metal-Hydrid) 20g
SJ.
       Post #: 13
RE: GWs A10 EDf55's - 12/21/2003 8:30:11 PM
