vortecks
Joined: 1/15/2004 From: Birmingham, UNITED KINGDOM Status: offline
The speed, the handling, the ruggedness, the balance....... everything is A1! The only thing i'm having problems with is starting the thing! I'm running an R3 plug and it doesn't like starting at all and uses 1 every other tank, is this the right plug to use and any tips on the best setup for running the engine? I've tried all the tuning methods but it EATS plugs. The best bit of fun I've had is locking the front brakes and taking off the front drive-shaft making it just rear wheel drive, power slide at it's best Had to put it back to 4WD because it eats tyres like that. This car is a damn good 'cheaper' alternative to the Hyper7 and the body fits too so it can even look like it's more expensive rival.
