15% or 25%??
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine
Seller:  XYZUSA
Details:   $249.00   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> 15% or 25%??
Page: [1]
Login
15% or 25%?? - 11/23/2003 4:07:41 AM
nitroman88-RCU
Status: offline
simple question
would i make more power running 15% nitro with 16% oil or 25% nitro with 18% oil??? both fuels have half syn and half castor.
thanks
       Post #: 1
RE: 15% or 25%?? - 11/23/2003 7:53:37 AM
rflasch
Status: offline
WELLLLLLLLL according to the drag race boys >nitro=>power!?!?!?
(in reply to nitroman88-RCU)
       Post #: 2
RE: 15% or 25%?? - 11/23/2003 5:43:10 PM
nitroman88-RCU
Status: offline
yes but less oil also means more power.
(in reply to rflasch)
       Post #: 3
RE: 15% or 25%?? - 11/23/2003 10:10:04 PM
ZAGNUT
Status: offline
more nitro=higher volume of fuel running through the engine= lower % of oil needed for proper lubrication......that's the theory anyway
dave
_____________________________
"I'll take the money- and you can have the rope"
       Post #: 4
RE: 15% or 25%?? - 11/24/2003 4:09:07 AM
downunder
Status: offline
Depending on the engine you may actually end up losing power with the higher nitro if its compression is too high. Easy fix though if this happens, just start experimenting with adding head shims. A cooler plug can help avoid detonation if the compression is too high but then the timing is wrong to get the extra power you're after. Unless the oil content goes to ridiculous levels then it has no affect on power because the volume of oil per cycle (which displaces the same volume of air) is so minute you'll never see any difference. What zagnut said is quite correct, in theory, but unless you know exactly the difference in fuel flow rates between different fuels then you'd be taking a big chance cutting back on the amount of oil.
(in reply to ZAGNUT)
       Post #: 5
RE: 15% or 25%?? - 11/25/2003 3:38:47 AM
nitroman88-RCU
Status: offline
im gonna start running the 25%, o.s. says that this engine is good up to 30%..
(in reply to downunder)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU1
