Steering pops out of place
Tower Hobbies
Logged in as Guest
  Printable Version
AXIAL AX10 SCORPION CRAWLER 12MM HEX WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> Steering pops out of place
Page: [1]
Login
Steering pops out of place - 11/23/2003 9:26:02 PM
Zorak
Status: offline
When i drive my electric rustler, and an obstacle hits one of the front wheels really hard, the whole steering mechanism pops out of place. it locks the wheels in a sharp turn one way or the other beyond the distance that trim can fix. to fix it, i have to stop the car, and turn the wheels in the opposite direction that they got locked into, and it makes "krkrkkr" noise while doing so. is this a normal function of the servo saver, or can i buy a better one?
       Post #: 1
RE: Steering pops out of place - 11/23/2003 9:47:48 PM
**MilkMachine**
Status: offline
your lucky that I have a electric rustler to! And I had almost everything that can happen to it happen!
lol
Well it sounds like the gears IN your servo broke. like one is missing a tooth because of really hard imapact! So know that your gear is broken it is skipping over the tooth of the broken gear so it is slipping on that gear. Its a little hard to understand, but here is the short versoin of it.
One of your gears in your servo is missing a tooth. and you need to get new gears to put in it. you can get all the gears for about 3 bucks. Once I replaced the gears it kept on doing it. so I just bought a Traxxas High Torqe Servo and Hasnt happened ever again!!
So you can either replace the gears for 3 dollers and have a CHANCE it will happen again are you can get a Traxxas High Torqe Servo for $18.99
Personally I would get the new servo. But its your call. If you have any questions about this post them and I will respond as soon as I see them!
_____________________________
If you arn't breaking parts, your doing something wrong.
(in reply to Zorak)
       Post #: 2
RE: Steering pops out of place - 11/24/2003 2:29:04 AM
Zorak
Status: offline
i checked the gears within the servo, they are all fine.
the thing is, everything works perfectly after i pop the wheels back to center. i think the servo saver is slipping off the servo.....
thanks
(in reply to **MilkMachine**)
       Post #: 3
RE: Steering pops out of place - 11/24/2003 2:52:02 AM
teamsquirreltail
Status: offline
Chances are that the spline on the gear that actually sticks out of the servo is stripped. It could also not be compatible with the servo you are running. Either get a new adapter that goes between the output spline and the servo saver, or get a new servo saver all together. The Kimbrough Large #5 is a good one.
(in reply to Zorak)
       Post #: 4
RE: Steering pops out of place - 11/24/2003 9:53:27 PM
**MilkMachine**
Status: offline
He just said he checked all the gears. O he checked all the gears on the inside.!
Is there a screw holding your servo saver on?
(in reply to teamsquirreltail)
       Post #: 5
RE: Steering pops out of place - 11/25/2003 3:43:50 PM
Zorak
Status: offline
theres a screw holding the servo saver to the rest of the steerng assembly. there is no screw holding the servo saver to the servo. is there a way to hold it there with a screw?
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
