RE: C-130 items    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: C-130 items
Page: <<   < prev  49 50 51 52 53 54 55 56 57 [58]
Login
RE: C-130 items - 8/17/2008 2:09 AM
longflyer
Score: 100
Last Login: 5/24/2013
Status: offline
for filling in holes on the glass.. head off to lowes or hd and purchase lite and easy spakling... super lite and sands easy and cheap.. paints easy,, good filler.
john
Hide Signatures
(in reply to rryman)
       Post #: 1426
RE: C-130 items - 8/17/2008 8:49 PM
ram3500-RCU
Score: 145
Last Login: 5/26/2013
Status: offline
quote:
ORIGINAL: longflyer
john
The 'Red Devil' brand of light Spackle is the best. It 'dusts' when sanded instead of balling up like some of the other brands do. I have tried them all. Thin CA can be wiped over the surface as well to give it more dent resistance. This can then be sanded as well.
_____________________________
Cheers,
Gary P. / use Steel Powder for ballast not lead. PM me for more information.
Hide Signatures
(in reply to longflyer)
       Post #: 1427
RE: C-130 items - 8/25/2008 10:41 AM
gunny11
Score: 100
Last Login: 4/1/2013
Status: offline
quote:
gunny
will the process work for the plastic props???? i am looking at 4 blade for os 65 engines....
john
No!! It won't stay together. Do Not Attempt it. Just wood.
gunny
HOME OF THE Aviation Concepts
1/5 scale PT-19 and 2-33
Hide Signatures
(in reply to ram3500-RCU)
       Post #: 1428
RE: C-130 items - 11/7/2008 4:52 AM
HercMan
Score: 100
Last Login: 1/13/2009
Status: offline
Gunny this is HERCMAN you may not remember me But I have had my 130 like yours for over 1yr and had been folling your Workmanship I read in 1 of your post that you can print wing plans and I would love to aquire a set of The plans that you Drew
If you would please contact me at the numbers I left for you in your in box
Hide Signatures
(in reply to gunny11)
       Post #: 1429
RE: C-130 items - 2/16/2009 9:47 PM
tonibr
Score: 100
Last Login: 3/16/2009
Status: offline
Hello all,, I have built a 72-inch C130 to be powered by 4 Speed 400 motors. The only thing the "plans" don't mention is where to balance the bird! Can anyone suggest at what percentage of root chord i should balancxe to be sure it will fly, please?
Hide Signatures
(in reply to HercMan)
       Post #: 1430
RE: C-130 items - 2/17/2009 12:06 AM
Lifer
Score: 148
Last Login: 5/25/2013
Status: offline
25 to 28 percent of the chord is pretty standard.
Hide Signatures
(in reply to tonibr)
       Post #: 1431
RE: C-130 items - 2/23/2009 3:07 PM
tonibr
Score: 100
Status: offline
Thanks, Lifer. I also found that the full-size plane uses 19% - 30% for takeoff, 16% - 30% for landing, which is quite a range.
I posted a build log of sorts here.........
http://www.modelflying.co.uk/forums/postings.asp?th=24182
There is a video link in one of the later posts.
Hide Signatures
(in reply to Lifer)
       Post #: 1432
RE: C-130 items - 3/13/2009 5:56 AM
rwolfe9
Score: 100
Last Login: 3/20/2012
Status: offline
What did you have to do about making sure there was equal thrust on each motor? I think that even though each motor is made the same, they have different characteristics, or is it so small that it doesn't even matter?
Hide Signatures
       Post #: 1433
RE: C-130 items - 3/13/2009 10:26 PM
tonibr
Score: 100
Status: offline
Hi rwolfe9,
quote:
ORIGINAL: rwolfe9
There IS a small difference in the thrust - I'm using two different types of Speed 400, with the higher revving ones on the two inside positions and the slower revving ones on the outer positions. There may be differences between individual motors, but there is no apparent effect on the flight characteristics - it just floats happily around the sky.
Toni
Hide Signatures
(in reply to rwolfe9)
       Post #: 1434
RE: C-130 items - 3/14/2009 8:17 PM
rwolfe9
Score: 100
Status: offline
Thanks. I'm building a B-52 and just wanted to make sure- 8 EDF's.
Hide Signatures
       Post #: 1435
RE: C-130 items - 3/16/2009 11:57 PM
tonibr
Score: 100
Status: offline
Take a look at these - multifan edf V-bombers.
http://www.rcgroups.com/forums/showthread.php?t=532258
http://www.rcgroups.com/forums/showthread.php?t=598936
http://www.rcgroups.com/forums/showthread.php?t=826825
Hide Signatures
       Post #: 1436
RE: C-130 items - 9/3/2010 12:43 PM
gunny11
Score: 100
Status: offline
Awful quiet out here!
Hide Signatures
       Post #: 1437
RE: C-130 items - 7/22/2011 3:09 AM
gunny11
Score: 100
Status: offline
Still quiet!
I made some evening flights at the WARBIRDS OVER DELAWARE with mine.
Gunny
Hide Signatures
       Post #: 1438
RE: C-130 items - 11/20/2012 8:48 AM
gunny11
Score: 100
Status: offline
even quieter?
Flew it again at WOD 2012.
It's 6 years old this month.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1439
RE: C-130 items - 11/20/2012 8:02 PM
Pitts532M
Score: 100
Status: offline
Gunny, what kit/plan is that model from, and yougive me some specs?  Thanks.
Hide Signatures
       Post #: 1440
RE: C-130 items - 3/24/2013 3:25 PM
BobRickey
Score: 100
Status: offline
If I remember correctly, it's a Quality Fiberglass kit, approx 102" ws
Hide Signatures
(in reply to Pitts532M)
       Post #: 1441
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
