bedlamite
WI, USA Status: offline
quote:
If it only gobbles your bandwidth, you are lucky. I have seen it crash several of my client's computers. It only "gobbles your bandwidth" when you happen to be searcing 17 different engines at the same time , I live far enough out in the sticks that dial up is the only option and I don't have a problem, IE is much worse at wasting bandwidth. If you are having a problem with computers crashing, I suggest you look elsewhere, Copernic isn't the problem. I've seen it run fine on everything from 98 to XP for years. Yeah, it's spyware, but do you really think Google doesn't keep track of what you search for? (/thread drift) Some specs on the Russian Ekranoplans: http://www.damp.tottori-u.ac.jp/Lab5/WISE/CHDBlist.html quote:
us true americans know that we invwnted ground efect Yep. It took the Wright brothers about 6 years to break out of ground effect.
