RE: Jamara Spitfire60 ARTF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> User Product Reviews >> RE: Jamara Spitfire60 ARTF
Page: <<   < prev  1 2 3 [4] 5 6 7 8   next >   >>
Login
RE: Jamara Spitfire60 ARTF - 1/5/2004 2:48:22 PM
Mac-
Status: offline
Internal firewall reinforcement pieces have now been added as shown and will be fibreglassed for final securement!
Why the manufacturers failed to reinforce the complete internal firewall perimeter is beyond me. Perhaps they believe that it's not necessary...but, imo, I believe it is!
Finally a 1/8th ply plate will be installed internally to reinforce the drilled mount holes....for my peace of mind!
The firewall, tank bay and servo bay will next be fuel-proofed!
Click to see fullsize image.
Click for fullsize
< Message edited by Macx -- 1/5/2004 2:49:02 PM >
(in reply to Mac-)
       Post #: 76
RE: Jamara Spitfire60 ARTF - 1/6/2004 10:00:14 AM
Mac-
Status: offline
The cowl is held in place by 4 screws...two either side of the fuz!
The problem with this is that fibreglass cowls will enevitably split/crack when screwed into position due to engine vibration.
1) I've therefore opted to fit 4 hardwood blocks made up from scrap. To the face of these has been added a small poece of wing elastic which the cowl will rest upon and help absorb vibration.
2) Each block is drilled with a cluster of 1.5mm holes. Epoxy will eventually run into these and help make a good foundation for the mounted blocks.
3) Likewise the firewall is roughened with glasspaper where each block will sit and 1.5mm holes drilled to about a 3mm depth.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Mac-)
       Post #: 77
RE: Jamara Spitfire60 ARTF - 1/6/2004 10:05:20 AM
Mac-
Status: offline
1) Epoxy is added and the blocks positioned.
(2 & 3) A drop of CA is added to hold each block firmly in position until the epoxy sets!
Now the firewall etc should be fuel-proofed!
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Macx -- 1/9/2004 12:27:47 PM >
(in reply to Mac-)
       Post #: 78
RE: Jamara Spitfire60 ARTF - 1/6/2004 12:44:20 PM
Mac-
Status: offline
Colour-coding the fuel line may save mix-ups later on!
Click for fullsize
(in reply to Mac-)
       Post #: 79
RE: Jamara Spitfire60 ARTF - 1/7/2004 1:02:37 PM
Mac-
Status: offline
1 & 2) The tank is fitted into place. Hard foam is best to support it as this helps eliminate tank vibration and possible fuel foaming!
3) The fibreglass cowl is trial fitted. Extra slots will be necessary to aid cooling!
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Mac-)
       Post #: 80
RE: Jamara Spitfire60 ARTF - 1/7/2004 3:33:45 PM
Mac-
Status: offline
Can anyone kindly offer advice on the best way to connect the throttle cable to the linkage on the engine throttle arm?
The throttle cable needs to run along the outer fuz. side from the servo bay and through the firewall.
There is not sufficient clearance to mount a mini servo inside the tank bay or on the firewall front!
So how do I produce a simple connection to the linkage????
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Macx -- 1/7/2004 3:32:30 PM >
(in reply to Mac-)
       Post #: 81
RE: Jamara Spitfire60 ARTF - 1/7/2004 4:35:19 PM
chris-s
Status: offline
If I understand your problem, try the following...
Using some threaded rod with a ball link on the end, fix this to the throttle arm extended to the side so that you get a linkage point closer to the side of the fus. It need not be all the way to the fus side, just enough to allow clearance down the side of the engine casing.
Then, ensuring the snake exists below or above this, use a piece of wire bent so that it goes forward beyond the throttle then double backs on itself to line up with the ball link. See the photo to get the idea, but please ignore the state of the model it is attached to!
Hope this works for you, since I'm planning on fitting a TT91FS when mine arrives!
Chris
Click for fullsize
(in reply to Mac-)
       Post #: 82
RE: Jamara Spitfire60 ARTF - 1/7/2004 9:12:24 PM
Mac-
Status: offline
Chris,
That seems to be an excellent solution so I'll go with that!
Also my ASP .91 has yet to be run in and the instructions state to use a 13 x 7 or 8. If I decide instead to go for a 3-blade prop I would use a 12 x 8. Is a 3-blade prop. okay to run-in a new engine or should I only use a 2-blade?
(in reply to chris-s)
       Post #: 83
RE: Jamara Spitfire60 ARTF - 1/8/2004 8:37:58 AM
chris-s
Status: offline
2 or 3 blades? Guess that should be ok using the general rule of "down one in diameter, up one in pitch". I've always bought 3-blade props for my scale competition models, but never ended up using them just in case I got it wrong!
Without the experience of using a 3-blade in 'anger', I would always opt for the 2-blade for a maiden flight, it's one less thing to worry about.
Chris
(in reply to Mac-)
       Post #: 84
RE: Jamara Spitfire60 ARTF - 1/8/2004 11:58:46 AM
Mac-
Status: offline
quote:
ORIGINAL: chris-s
....Without the experience of using a 3-blade in 'anger', I would always opt for the 2-blade for a maiden flight, it's one less thing to worry about.
Chris
Sound advice, Chris...thanks!
I'll run the engine in on a 13 x 8 2-blade prop. and switch to a 12 x 8 3-blade after the first few flights are completed.
A 90mm plastic cowl can be bought for under £4 if you don't want the expense of an aluminium one!
(1, 2 & 3) The cowl retention screw holes are marked off and drilled out with a 2mm drill.
(3 ) The exhaust outlet is cut away with sufficient space to attach the muffler after the cowl is fitted!
Note: ***When drilling the cowl watch out for cracking on the painted surface.***
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 85
RE: Jamara Spitfire60 ARTF - 1/9/2004 12:41:30 PM
Mac-
Status: offline
1) The supplied horns are good quality!
2 & 3) It's the first time that I've ever seen these type of clevises. A drop of CA soon produces a sound clevis which have a positive click when closed.. Rather than use the suplied heat shrink tube to secure the horn connection I prefer fuel tube which is just as effective and easier to move if further adjustments are required!
4) The rudder and elevator slots are cut out...one either side, and the assembled dowel/wire control rods fed through!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Mac-)
       Post #: 86
RE: Jamara Spitfire60 ARTF - 1/9/2004 4:59:43 PM
Mac-
Status: offline
So far I have been very pleased with this kit. But now I have met my first major niggle.
The supplied cockpit is, imo, of poor quality. The excess flash moulding needs to be trimmed away to produce an accurate fit on the fuz.
As I carefully commenced the cutting out procedure the material split open as shown. The front part is weak which surprises me as the general kit quality is pretty good.
Perhaps it is a one off and I've now contacted the supplier for their comments!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Macx -- 1/9/2004 5:32:50 PM >
(in reply to Mac-)
       Post #: 87
RE: Jamara Spitfire60 ARTF - 1/9/2004 6:56:59 PM
Mac-
Status: offline
My supplier has just contacted me and is sending on a replacement cockpit free of charge. It pays to contact your supplier if you have a problem with a model and, initially, a few images with an e-mail is probably best. Sometimes an image speaks louder than words!
(in reply to Mac-)
       Post #: 88
RE: Jamara Spitfire60 ARTF - 1/10/2004 4:48:36 PM
Mac-
Status: offline
1 & 2 )The aileron horns are fitted into position!
3) Another minor problem...the screws are too short. At 22mm these screws need to be at least an additional 5mm in length!
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Mac-)
       Post #: 89
RE: Jamara Spitfire60 ARTF - 1/12/2004 2:18:10 PM
