Mac-
Joined: 7/5/2002 From: private, AE, UNITED KINGDOM Status: offline
quote:
ORIGINAL: chris-s ......of course, you could have drilled a larger hole in the throttle arm! Whilst I was away my replacement kit finally arrived - yippee!! Just need to clear the bench to make way, currently finishing off a triple-engined Wot4. Chris Hi Chris, My only concern with drilling a larger hole in the throttle arm is that my ASP .91 is brand new and , as yet, un-run. So if there should be a problem with it, though I doubt it, the engine warrenty would probably be void? You state that your replacement kit has finally arrived which I assume is the Spit!. What was the problem with the original kit?
