Mac-
Joined: 7/5/2002 From: private, AE, UNITED KINGDOM Status: offline
quote:
ORIGINAL: websterflyer Just completed my electrified Spifire from Jamara ,,The whole thread has been very useful to me in construction. The plane weghs in at 3.6Kg wih a Lipoly battery --6P 5000 MAH--- The motor is an old Astro 40 FAI geared.driving a 12x6 prop. I have also used 20 GP3300 cells which are quite a bit heavier these gave a 16 min flight. Longest flight to date has been 26 minutes !! Its really fantastic enormous loops from straight and level slow passes etc etc . C of G is bang on 110mm ..with no problems . Just waiting for the retracts at this time . I may have missed it in the thread but has anyone found a match for the camoflage covering ? Best wishes Adrian Whatmore Taunton Somerset Adrian.....an outstanding effort - well done! I'm sure that your your successful conversion to electric of the Jamara Spitfire will inspire others to do likewise! Regarding the colours I suggest that you look at the Flair range of paints. The 125ml pots may be what you are looking for. The Light grey and dark grey if mixed carefully will give you the matching sea grey shade already on the model. Flair's drab olive is nearest shade for the green. Applying an etching primer to the Oracover first, such as Solarfilm's Prymol, will provide a keying base for the paint. If you have any images of your model please add them to this thread. Good luck with you flights!
< Message edited by Macx -- 8/5/2004 12:02:52 PM >
