fuel storage    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> fuel storage
Page: [1]
Login
fuel storage - 11/29/2003 3:21 PM
buchtes
Score: 145
Last Login: 4/16/2013
Status: offline
what is considered the maximum amount of time to store fuel before it goes bad.
Does container, temp. light make any difference?
Finally, where can you get some good quality metal cans with a good airtight lid?
Hide Signatures
       Post #: 1
RE: fuel storage - 11/29/2003 5:29 PM
flythe9
Score: 100
Last Login: 5/5/2004
Status: offline
I am using fuel that is 4 years old stored in the original plastic bottles in a unheated outside shed.
No problems with the fuel.
There was recently an article in one of the model mags. where their engine man showed an engine running with 20% water mixed in the fuel.
The article went on to show that most of the "fuel storage, water and condensate" issues heard at most fields and published in some mags. are false.
see page 66 Model Aviation Jan. 2004 issue. The article starts with the boldface "As regular readers"
< Message edited by flythe9 -- 11/29/2003 9:31:15 AM >
_____________________________
It is not a crash, It's an unplanned, unscheduled landing
Hide Signatures
(in reply to buchtes)
       Post #: 2
RE: fuel storage - 11/29/2003 5:44 PM
POWERMASTER
Score: 100
Last Login: 5/6/2009
Status: offline
Flythe9
Powermaster fuel comes in metal cans with resealable caps. Might want to try this
if you are looking for metal cans. If fuel is sealed and has not been exposed to moisture
then life of the fuel is almost indefinite.
< Message edited by POWERMASTER -- 11/30/2003 4:15:04 PM >
Wendell Hammond
Hide Signatures
       Post #: 3
RE: fuel storage - 11/29/2003 10:43 PM
buchtes
Score: 145
Status: offline
thanks flythe9 & Wendall for your input. I still have a unopened can of Powermaster on the shelf I bought 3 months ago, been running a mix between homebrew and Ritch's Brew. I definitely will reuse the can can in the future, trust it more then the plastic jug. Still no answer's on the lifespan of the fuel, that stuff may last forever???
Hide Signatures
(in reply to POWERMASTER)
       Post #: 4
RE: fuel storage - 11/30/2003 12:18 AM
mikefuture
Score: 100
Last Login: 5/22/2013
Status: offline
I would think that if the fuel was kept in it's original container, sealed tight, and kept in a cool dark place that it would last indefinitely.
Hide Signatures
       Post #: 5
RE: fuel storage - 12/11/2003 5:20 AM
doctorgo
Score: 100
Last Login: 12/15/2012
Status: offline
I personally witnessed 20 year old K&B fuel in a rusted can, opened for the first time, used with success some years ago. I also have 4 year old Morgan Omega fuel(I over-bought)kept in my basement, that I use regularly. Yes, I would agree, shelf life is indeed lengthy.
Regards,
DrGO
Hide Signatures
(in reply to mikefuture)
       Post #: 6
RE: fuel storage - 12/11/2003 6:09 PM
rajul
Score: 105
Status: offline
Sounds good !
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
(in reply to doctorgo)
       Post #: 7
RE: fuel storage - 12/18/2003 8:38 AM
Live Wire
Score: 6329
Last Login: 5/23/2013
Status: offline
The only way fuel get bad is if the Nitro And Alco. evaperates, Have Red Max 7 years and still good. Had fuel left from my store and using it up!
Hide Signatures
(in reply to rajul)
       Post #: 8
RE: fuel storage - 12/18/2003 3:38 PM
rjbarthel
Score: 100
Last Login: 2/17/2013
Status: offline
has anyone seen 2 stroke fuel loose its color ! I had a gallon of sig 15% that was about half full that went from pink to nearly clear !! It seemed to work ok ! the only thing I can think of that was different with this jug of fuel compaired to others Ive had was it had been in the sun light much more !! thanks RB
Hide Signatures
(in reply to Live Wire)
       Post #: 9
RE: fuel storage - 12/18/2003 7:29 PM
3d-aholic
Score: 100
Last Login: 9/29/2009
Status: offline
I used fuel that was 8 years old and if anything it worked better than the new stuff. Key is the plastic bottle were stored in the original plastic bottles with zero head space and the red plastic stopper in first and screw cap on top. They were in the original fuel case carton sealed with no light.
Light, heat, oxygen and water provide catalysts for reactive products....limit those and your fuel with last longer.
Hide Signatures
(in reply to rjbarthel)
       Post #: 10
RE: fuel storage - 12/20/2003 7:59 AM
Fuelman
Score: 100
Last Login: 9/27/2012
Status: offline
Unopened fuel either in bottle or can has a nearly indefinate shelf life. Keep it out of the sun.
Some companies use dyes that may lose some briliance after exposure to the sun, this should not indicate a problem with the fuels burn-ability if sunlight was the only cause for the color change.
Fuelman
Cooper Fuels LLC
Hide Signatures
(in reply to 3d-aholic)
       Post #: 11
RE: fuel storage - 12/21/2003 10:56 PM
RaceCity
Score: 100
Last Login: 10/13/2007
Status: offline
Wine doesn't spoil with age? Why should fuel?
Ever hear of anyone throwing away a bottle of Lafite Rothschild because it was old?
Keep it away from temp extremes...light and the atmosphere and it's good for a LONG time.
As for the bit on water in the fuel being good? I'd like to see that test repeated with r/c engines....
Show me how good the idle...transition and reliabilty is. JW's article in MAN was a lot of
hoo-hah.
Water in glow fuel is B-A-D.
'race
Hide Signatures
(in reply to Fuelman)
       Post #: 12
RE: fuel storage - 12/22/2003 5:27 AM
rajul
Score: 105
Status: offline
Best way to keep fuel from getting bad ................burn it up !
Mike Marks
RCU Moderator
Hide Signatures
(in reply to RaceCity)
       Post #: 13
RE: fuel storage - 6/13/2012 9:57 PM
MrShoes
Score: 100
Status: offline
I know this is a very old thread, but I don't believe shelf life of glow fuel is almost indefinate. I bought some Powermaster YS 20/20 and never opened the can. Kept it stored in my garage for about 2 years. I opened the seal for the first time and the fuel had lost its go-go, could net get engine to run. I had to buy a new can and the engine fired right and ran like a champ.
Hide Signatures
       Post #: 14
RE: fuel storage - 6/14/2012 1:35 AM
JPMacG
Score: 123
Status: offline
I am now using fuel that I purchased 3 years ago. My Saitos and Enyas run on it as well as new fuel.
Perhaps your gallon somehow became contaminated with water (leaky seal?) or perhaps it was a bad batch from the get go.
My personal experience is that 4-strokes do not run well on fuel that has been contaminated with water, however. 2-strokes seem to run OK on that fuel.
Hide Signatures
(in reply to MrShoes)
       Post #: 15
RE: fuel storage - 6/14/2012 4:17 PM
earlwb
Score: 584
Status: offline
For glow fuel there is no shelf life for the fuel. It is good for a indefinite period of time. I have used glow fuel that was over 20 years old with no problem. The trick is to store it so the sealed fuel container is not directly on a concrete floor and out of sunlight. Then the stuff is good to go many years later. The container may puff up when hot and suck itself in when cold, but that is OK as it is sealed so it can't leak.
Now for gasoline it is hard to say, without stabilizers in the fuel, less than a year. With stabilizers a couple of years or more. Some gasoline blends don't store well for all that long due to the hydrocarbon chemicals they use in the stuff. The other problem is that many gasoline containers can breathe, letting the more voltaile chemicals evaporate or allow it to abosrb moisture (ethanol)  which shortens the shelf life even more.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to JPMacG)
       Post #: 16
RE: fuel storage - 6/15/2012 5:24 AM
1QwkSport2.5r
Score: 155
Status: offline
I now mix my own fuel, but when I bought fuel at the LHS, I always squeezed the jug without touching the cap and if I heard any leakage from the cap I grabbed a different jug. Leaky caps surely mean contamination is probably. As I understand, nitromethane breaks down in direct sunlight. I do not know if artificial light is included, but keeping it in a cool dark place isnt a bad thing. I've used fuel I mixed up a year ago that ran just fine.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to earlwb)
       Post #: 17
RE: fuel storage - 6/20/2012 1:37 AM
MrShoes
Score: 100
Status: offline
quote:
ORIGINAL: earlwb
Curious as to why storage on a concrete floor is bad for fuel?
Hide Signatures
       Post #: 18
RE: fuel storage - 6/22/2012 2:36 PM
Sport_Pilot
Score: 233
Status: offline
I have heard this but have not had a problem with fuel that gets occasional sunlight, other than the dye turning dark, but runs fine.  Angus site says nothing about this, but says to store in original containers so not sure if this is true or not.  I have no idea why storing on a concrete floor would be bad.  Since concrete floors are normally cool seems like it would help.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 19
RE: fuel storage - 6/22/2012 2:46 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: mikefuture
I recently opened some bottles of 15% Cool Power that were in a climate controled back room that were 14 years old. 1 was actually opened way back when but I kept it sealed W/my fuel lines plugged into the bottle. Both bottles were fine & I could determine no peak or idle RPM between the 2.
Alcohol fuel deteriorate when left open to the atmosphere where evaporation & moisture absorbtion degrade their quality. Kept sealed, out of direct sunlight & @ reasonable temperatures, they last a long time W/no ill affect.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 20
RE: fuel storage - 6/22/2012 7:52 PM
Bobhend
Score: 100
Last Login: 12/1/2012
Status: offline
Gasoline 10% ethanol [E10] on the other hand can't be trusted for the next season.
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 21
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> RC Fuels >> fuel storage
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.735RCU1
