Os FS-70 Surging
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler for Saito's
Seller:  RC Specialties
Details:   $49.95   |  10/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Os FS-70 Surging
Page: [1]
Login
Os FS-70 Surging - 4/24/2002 12:54:47 AM
Peter_OZ
Status: offline
I have a new FS-70 fourstroke in my Astrohog. It continually surges at high throttle seetings. No matter how I adjust the needle valve it still does it. I have muffler pressure to the tank and the tank is correct height. There is no pump on this motor Fuel is 5% nitro, 18% coolpower, 78% methanol. appreciate any advice thanks cheers Peter
       Post #: 1
Os FS-70 Surging - 4/24/2002 1:12:22 AM
HavinFun
Status: online
I use Wildcat 15% Extra, all my 4-strokes love this stuff. I used some Omega 15% once and noticed on my 91s the rpm would surge/fluctuate at full throttle. CoolPower 15% also runs great.
(in reply to Peter_OZ)
       Post #: 2
I have os 70 surpass - 4/24/2002 2:59:00 AM
Shortman
Status: offline
I also have used wildcat fuel with great results. My local hobby shop sells wildcat but put there label on it. This is what it is nitro 10%, 18% oil content, 80/20 synthetic castor blend works great
       Post #: 3
Os FS-70 Surging - 4/24/2002 7:48:50 PM
rctrax
Status: offline
You might try checking valve clearence espesialy exhaust valves
       Post #: 4
Os FS-70 Surging - 4/25/2002 12:44:38 AM
Shortman
Status: offline
speaking of valve clearence, i need to check that!
       Post #: 5
FS70 surging - 4/25/2002 8:51:37 PM
Peter_OZ
Status: offline
thanks for the tips guys. i hadn't thought of valve clearance as it is a new donk. I did take muffler pressure off and it now screams along however the low and mid range transistion is awful. I will have a play with the valves then the other adjustments and see how it goes cheers Peter
       Post #: 6
OS 70 - 4/25/2002 9:08:00 PM
FIVESQUARE
Status: offline
Just for grins....Check for an airleak......The fuel tank plug would be a good place to start...Make sure screw is gutentite.Then replace all fuel lines with "good stuff". Good Luck, DOC
       Post #: 7
OS FS-70 Surging - 4/29/2002 3:36:36 AM
Peter_OZ
Status: offline
thanks for all the advice guys I checked the valves and they did require adjusting. They are now set and it has helped a bit. I tried with and without muffler pressure. It really does like no muffler pressure so that is how it is set up now. Engine is screaming along and I can pull inverted passes pulling neg g into the horizontal with cutout or faltering. Vertical stall turns and square loops are now also possible cheers from downunder. Peter
       Post #: 8
good! - 4/29/2002 3:46:55 AM
Shortman
Status: offline
glad to hear it running good.
       Post #: 9
RE: Os FS-70 Surging - 5/22/2008 11:09:34 AM
speedair
Status: offline
Use 10 to 15% four stroke fuel
(in reply to Shortman)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.906RCU4
