VinceHerman
Joined: 9/5/2002 From: Wadsworth, OH, USA Status: offline
Hi Razmo, Brother #2 used a Piccoboard until the magic smoke escaped. I do not know which version of the board it was. I do know that the most experienced, knowledgable piccolo people alive report that the Piccoboard does not behave as a true head hold gyro. It is close. It does the job. But seperates with a true head hold gyro will perform that task better. Brother #2 is still early in his use of the hlg200 gyro, so it is early for me to be able to make comparisons. I did use his hlg200 in my picc before putting it in his (the advantage of being the one to order the parts!). It behaved for me axactly as it should. The tail stayed where it was, through different throttle and cyclic inputs. Very similar to the Futaba gy240, but a lot lighter. Yes, I believe that seperates is the best way to go functionality wise. I also feel it is the best way to go cost wise. Why replace all 3 components if only 1 is broken?
