EASYTIGER
NY, USA Status: offline
I've had a bad gallon of fuel throw me into the most incredible tizzy of changing plugs, adjusting valves, removing the fuel tank... Change the plug first, then change the fuel. One of the most easily overlooked things. And it does not matter if the fuel is old or not, not one bit. It could be bad at the factory. Just had an episode with the new Kamdax ducted fan unit. Had been running 30%, bought some Odonnell 40%. Had less revs and my first dead stick. Concluded that the Kamdax will not run well on 40%. Wrong. Coulple of weeks later, tried the same 40% in a Tokifan, and it would not run either. Son of a gun, the fuel was bad right out of the bottle. It happens. By the way, on my Saitos, I have been running 30% heli fuel with a little extra castor thrown in...they LOVE it. Tons of power, long life, great idle. OS F plug...
