RE: Flair 1/4 Scale PT-17 Stearman Review
Tower Hobbies
Logged in as Guest
Users viewing this topic: fightingfalcon839
  Printable Version
More Resources on the
P-51D Mustang - 40
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Flair 1/4 Scale PT-17 Stearman Review
    Page: <<   < prev  20 21 22 23 [24] 25 26 27 28 29   next >   >>
    Login
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 1:05:42 AM
    chasrb
    Status: offline
    Jack1933, the manual does state clearly the incidences for the wings and as far as this manual I scanned in goes, it cannot be refuted. These manuals are the original declassified and then non-classified versions.
    Perhaps the guy you know has either made personal changes to the wing incidences on the planes he is associated with and found their stall rates to his and his customers liking or there is a non-military manually with specs more directed to the “crop duster” which may have a more critical stall requirement then that of the Stearman in use as a military trainer.
    _____________________________
    Chasman
    (in reply to Cybertom)
           Post #: 576
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 2:35:01 AM
    jack1933
    Status: offline
    Ok You win Im just telling you that your info is wrong, because my friend just this day read the settings to me, and if you want to set your plane up in this manner, then try it and see what happens. Remember the way my plane is set up -2 degrees on the top wing with reference to the bottom wing, requires no down trim on the elevator at any speed, is a 16 year old tried and proven fact. Have sold many sets of these plans. I know what works and what does not work on many biplanes. Thanks for the offer of the manual, but dont really need it.
           Post #: 577
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 3:03:54 AM
    Cybertom
    Status: offline
    Jack1933,
    I'm glad you have had such good success with the incidence settings you selected for your Stearman. Show us some pictures of this tried and true aircraft.
    Jack1933? Is that the year you were born? That would make you 74 right? If that's true "keep em flying" Jack. I hope I do as well.
    < Message edited by Cybertom -- 4/11/2007 3:20:51 AM >
    Real airplanes have 2-wings and round engines!
    (in reply to jack1933)
           Post #: 578
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 5:40:33 AM
    outacontrol41
    Status: online
    Okay, now it's time for me to add my two cents worth about this......
    Click to see fullsize image.
    Click for fullsize
           Post #: 579
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 10:41:48 AM
    chasrb
    Status: offline
    Jack1933, just for grins and giggles can you have your friend send you the page where he found this info? If it is from a military Stearman manual it would be an interesting find to see that there were differences of that type.
    Just for clearing the air here, those of us who really use this forum are not the combative type, we seek only information and information by its very nature does not come unless questioned. So we ask questions only in a good natured way for clarity and understanding.
    It is obvious to those who have modeled for many years that a 1 to 1 scaled down version of an airplane spec by spec generally will not fly well at all. There are gives and takes in appearance and in surface configurations that have to be made in order to have an airworthy scale aircraft, including the incident of attach by the wings and wing length.
    The Flair kit is a good kit, the mfg took it to a certain level in flight characteristics and scale appearance, we are trying to take it to the next level.
    Lastly, anything that makes it fly better is welcome...
    Chasman
           Post #: 580
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 3:47:07 PM
    jack1933
    Status: offline
    Yes Ill be 74 in may Thanks for the kind words, cybertom, hope you can be active also as you age. Im going to fly 5 -I.M.A.C contests this year with a 40% laser, gonna mix it up with the kids--lol. the friend is sending me the correct Boeing rigging, page, when I get it will post on here. BTY, have seen the drawing cybertom posted and it is military and not the correct rigging for the Stearman, and my friend did not make any changes to the offical Boeing manual. The full size Stearman is rigged with incedence guages from Boeing, so it will be in specs. Dont know how to add a pix to this message, went to ---click here to update images and files-- and selected a pix to add but it did not show up here. So if cybertom gould give me a lesson, would appreciate it..Later Jack
    Click for fullsize
    (in reply to chasrb)
           Post #: 581
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 3:54:40 PM
    jack1933
    Status: offline
    Oh the pix did show up--oh well guess I dont need a lesson. the damage happened when a wood prop blew up. This pix was taken at the Guthrie Ok fly in in 2005. All the damage was repaired quickly, and thats when i changed the top wing from1.5 degrees to + 2 degrees--bottom wing at +3 degrees.
           Post #: 582
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 4:06:23 PM
    jack1933
    Status: offline
    Hi Cybertom Enclosed are some more pix of this old bird, stopped counting after 600 hrs on the airframe, prolly close to 900 now.
    Click for fullsize
           Post #: 583
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 4:10:06 PM
    jack1933
    Status: offline
    Did not know one could only send 1 item at a time. Perhaps a lesson on how to send more than 1 pix is in order--- thanks for any help
           Post #: 584
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 9:00:35 PM
    chasrb
    Status: offline
    Hi Jack, the best way to upload is to reply to a message then you can upload up to 12 pics at one time.
    I would really enjoy seeing the non-millitary manual, that would be of value to me.
    Chasman
           Post #: 585
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 9:46:23 PM
    Cybertom
    Status: offline
    Jack1933,
    That's one hell of a good looking NAVY Stearman no matter what the incidence! It has a very scale appearance. What scale is it and what did you use for a reference?
           Post #: 586
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/11/2007 10:26:21 PM
    chasrb
    Status: offline
    Cybertom, did you use Kevlar or coated wire for your pull pull? I have not use Kevlar before, I have just never used it .
    Chasman
           Post #: 587
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/12/2007 12:22:01 AM
    Cybertom
    Status: offline
    Coated wire.
           Post #: 588
    RE: Flair 1/4 Scale PT-17 Stearman Review - 4/12/2007 1:01:13 AM
    jack1933
    Status: offline
    Hi Chas i have the boeing manual, book cover and rigging, in an email. Please tell me how to get it on here. thanks jack
