jack1933
OK, USA Status: offline
HI Chas This may help till I can get the details you wanted downsized. My cabanes are 2024 t4 aluminum, covered with balsa, shaped and covered with whatever covering you use. They are attached to plywood reinforced doublers at the front inside the fuse box with 2 ea. 10-24 bolts, into t nuts, the rear are the same, except 1 bolt, the tops of the cabanes are attached to the top center section, and recesed into the root with 10-32 flat head bolts into t nuts. The only reason for the difference in bolts is, they were what was on hand, actually one should use coarce threads in soft metals, and fine in steel, either will suffice in this application. As you can see from the picture, the wing slides onto a 2024 aluminum pipe with .049 wall, and the wings are held rigged, with flying/landing cables attached, then a jig was constructed, using the pipe holes, and the antirotation pins, as anchoring points while the wings are off the plane. Takes about 3 minutes to put the plane together at the field. Assumed that a similar system is used on the Flair model. Will get some copies of the info you requested today. the landing gear is also 2024-t4 aluminum, the reason is: 2024-4 is about 2 times stronger than 6061-t6. Later
